![]() | Home > Technical (L322) > Newbie - Some advice please |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6374 ![]() ![]() ![]() |
Air con regassing will be about £100.
ukrangie Member Since: 20 Jun 2009 Location: Kent Posts: 520 ![]() ![]() ![]() |
Correct me if I am wrong here but may want to check that the recalls are done particularly the one for the front diff? There were a few vehicles that had issues with the front diff due to a manufacturing fault in the handover between BMW and Ford. This was rectified in the 2005 model from memory. |
UKRangie,
The air-con might just be a bigger problem than just a re-gas, If the seller doesn't use it the seals in the unit don,t get lubricated and then when it is switched on they tear. A common and expensive problem with people who don't just leave it on. 2008 MY Supercharged
sms720 Member Since: 20 Sep 2009 Location: Northern Ireland Posts: 33 ![]() ![]() |
OK Thanks everyone, the gist of what I am reading says the most important thing to check with dealer is the drive shaft replacement, I am correct in assuming if it has not been done it can be done now FOC?
If I am looking at a 2nd hand car with no warranty I notionally 'put aside' about £1000 in my budget for things to fix or replace. I would guess this is about that worst case.
For the Pixels, eBay is your friend as it's a common BMW problem, people will fix it for you:
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 ![]() ![]() ![]() |
as all the above annnnddd as for the a/c pop open the bonnet leave drivers door / window open when the engine is running in idle in park put heater controlls on cold and press the a/c button and lissten for the clutch in the a/c pump engaging / single click / thud noise also watch the revs they should rise slightley if no thud / engagement then eigher the a/c ecu recognises the gas is too low pressure or a bigger fault perhaps hope fully youll here the clutch engage and just wants topping up |
Brilliant thanks everyone.
FYI
They broke my steering column when mine went in to have the recall done, then wanted to charge me £800 plus labour to fit. Smacked of "we have to do this for free but we'll get our pound of flesh from you" Also at that mileage if there was a misalignment issue it would have surfaced by now - at 115k I decided not to have the work done because of the follow on problems that I would have then had to pay for. ![]() |
I was told by the Dealer that if the front driveshafte WAS going to explode, it normally happens at about 60K, if it goes past this (as most did) then it should be fine. Sometimes you do have to wonder whether just leaving it alone is a better bet.
Ok final 2 questions as I am going for a final test drive before buying!
You will know if it's not working because it will be pretty much un drivable. But there is an obvious self explanatory knob on the dash by the heater controls.
