Home > General > 20" tyre pressures ??
Marksman
I'm running STD 20" wheels with Scorpion tyres with nitrogen, anyone have accurate pressures for front and rear STD load ? or is it just standard pressures as per manufacturers data?
Post #73501 23rd Jul 2011 8:39pm
mercuryf1
Malaysia 2015 Range Rover SVAutobiography 5.0 SC V8 Loire Blue
Correct tire pressure measurements should be found on the sticker on the drivers door. In what way do you find filling tires with nitrogen better then filling with normal air? '01 1.8i Freelander. Grey/ grey
'06 4.2 S/C Buckingham Blue/ Parchment
'15 5.0 S/C SVA Loire blue/ Black
Post #73502 23rd Jul 2011 8:51pm
Marksman
I find that the pressures are maintained for far longer (up to 6 months) without having to keep topping up, I believe the tyres last longer as the temperature / pressures are less variable. These are at 22000 as still plenty life left
Post #73503 23rd Jul 2011 8:57pm
Paul J.
Speaking as a chemist, I would expect air to maintain a more constant pressure versus nitrogen.
Paul
Post #73504 23rd Jul 2011 9:02pm
mercuryf1
now this is interesting! my 20' Continentals are wearing out on the sides, even though I regularly balance them, swap them around and use the car rarely within the first year of ownership! I think its time to try nitrogen! '01 1.8i Freelander. Grey/ grey
Post #73505 23rd Jul 2011 9:02pm
nitrogen wont help..wheel alignment will..
Post #73507 23rd Jul 2011 9:04pm
Maybe but worn shoulders is a known problem with the Continentals . 2008 MY Supercharged
Post #73510 23rd Jul 2011 9:22pm
Does nitrogen make the car lighter? Whistle Mr. Green Got - 2017 SDV8 Autobiography in Loire Blue
Post #73512 23rd Jul 2011 9:34pm
mercuryf1
Are there any better tires out there? since 20' Conti's come as standard equipment for the S/C... '01 1.8i Freelander. Grey/ grey
Post #73535 24th Jul 2011 4:50am
