![]() | Home > Technical (L322) > Eas fault ? Door lock |
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 ![]() ![]() ![]() |
Hi Bigstu,
Bigstu Member Since: 24 Jul 2011 Location: Essex Posts: 7 ![]() ![]() ![]() |
Hi, tried that thought it only re calibrated the steering angle sensor but didn't work anyway lol |
sometimes dis-connecting the battery re-sets the ecu's... |
The side door latches incorporate a sensor to provide a door status signal to the BCU.
that makes a lot of sense ... |
Fitted new door lock only took 5 mins max
did you do this? |
Yeh tried it before I replaced the door lock will try it again |
Didn't work again.
All sorted went to Fortune 4x4 in laindon to get a code read out compressor overheat codes was all reset and light now off etc
why did you disconnect the compressor stu? |
I disconnected the wiring harness in the spare wheel well to check for a live feed and see if I could check the can bus lines etc but I think the ecu shut the system down so didn't get an plausible readings |
understood. |
