![]() | Home > Technical (L322) > EAS problem input needed |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6381 ![]() ![]() |
I'm no expert but while I was reading through it I was thinking "the sensor is bound to be the issue". As you have replaced the sensor and thought about the cross link valve my only (non technical) suggestion would be, replace it again??
If the Plausability Logic is corrupt it could throw a code even if there is no problem? Perhaps the EAS ECU itself is faulty and giving an incorrect fault.
BBS SPY Member Since: 20 Apr 2009 Location: Limassol Posts: 101 ![]() ![]() ![]() |
Hmmn, i once worked on a sport showing FR sensor fault which was replaced with no effect.
I don't understand why the sensors at each corner should be more or less expensive? Is the FL corner a cheaper corner to fix for some reason? How odd.
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 ![]() ![]() ![]() |
under the drivers side sill there is a tank with a pressure sensor in the end this sensor measures system pressure but is only replaceble with the tank and at the other end of the tank more towards the rear of the sill theres a 5 way valve block thats non serviceble it could be eigher of these more so the valve block hope this helps |
Ah the plot thickens.
I know it has been about 6 months since my last post on this problem.
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 884 ![]() ![]() ![]() |
Did you ever use soapy water on the air spring? |
Yep tried that but could not find anything which did not surprise me because if the vehicle was left standing it would not lower any over time. It seemed to only leak and lower the corner when driving giving a lop sided feel much of the time. followed by the Articulation error fault being registered and the system going off line.
