![]() | Home > Technical (L322) > Different size spare to rest of alloys, will it work? |
wedgel322 Member Since: 20 Jul 2011 Location: Leeds Bradford Posts: 161 ![]() ![]() ![]() |
Hi, just noticed that although my spare looked 'at first glance' to be identical to the other four alloys on the car it actually is not !!! |
Thanks for advice, i will check it out 2003 Range Rover HSE 3.0 TD6
http://www.1010tires.com/tiresizecalculator.asp |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35861 ![]() ![]() |
you'll find loads of members have upgraded from 18''/19'' to 20'' but have only brought 4 wheels so the spare is still the old size [like me]...i luckily find out in time that my 18'' spare had to use the smaller black nuts whereas my brought 20'' had to use the newer larger silver nuts...so had i had a puncture the spare would not have fitted, when i realised i put a set of smaller nuts in with the spare, just in case i needed to use it.. |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6382 ![]() ![]() |
In theory you can run the car on 18s, 19s and 20s all at the same time as the rolling circumference is the same (within tolerances)
