![]() | Home > Maintenance & Mods (L322) > Suggestions for cleaning a-pillars and window rubbers |
RRVSE Member Since: 18 Apr 2009 Location: Bury Posts: 597 ![]() ![]() ![]() |
Hi all, after some suggestions please. Recently I somehow ended up with speckles of white paint down the entire passanger side of my car (haven't a clue where it came from though). I have used a clay bar and lubricating oil to successfully remove all the paint off the main bodywork, bonnet and roof and have cleaned the glass OK, but the A-pillar , c-pillar and window rubbers are more of a trick. I initally clay barred the a-pillar a bit but not too successfuly. Also need to clean the side step, wing mirror casing and mud flaps. Anyone got any recommendations from previous experiences before I start to try out different cleaning methods as would be easier to know what works in the first place?
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3949 ![]() ![]() ![]() |
I've done this with white spirit when my sons car got speckled with whatever paint they use on house walls. It won't do any harm unlike thinners which might. Geoff |
letsavit2 Member Since: 16 Oct 2010 Location: essex Posts: 854 ![]() ![]() ![]() |
try the wife's nail varnish remover as well, that will not harm your paint. 2004 black Vogue TD6 |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1528 ![]() ![]() |
Yeah yeah, "the wife's" ![]() Sorry only kidding, just couldn't resist- it's good advice acetone is a decent solvent ![]() |
MMMmmmm, a-pillar covers are black plastic. I wouldn't try any solvent in a visible spot the first time round... |
+1 for testing Acetone somewhere it doesn't show - cellulose thinners is similar stuff and it thins paint ! Geoff |
Hi Guys, thank you all for your advice. Obviously, I'm only removing paint off the plastic and rubber parts of the car , so I'm assuming the plastic is impregnated with a black colourant and the same for the rubber so I'm a bit wary what I use (goes back to years ago as a kid where I couldn't get a sticky label off a cassette tape case so used a dab of petrol which basically immediately gave the plastic case a frosted look finish, but what did I know then!). As Steve says, I'll try a less conspicuous place first and then do the part thats easiest to replace if it goes wrong!!!!
