Home > General > tyres
tommac22
United Kingdom 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
tyres
All,
The front tyres on our fullfat are past there best- when replacing does onw need to replace all 4 as it has been suggested to me by one garage- or can i just replace the fronts and leave the rears as they have plenty of life left!
Post #74171 29th Jul 2011 4:56pm
just replace the ones which are worn....dont listen to the garage ,they are only trying to make money out of you...
Post #74172 29th Jul 2011 4:59pm
rory_mcw
on all of my 4wd cars i have always changed the 4 at the same time.
Post #74175 29th Jul 2011 5:14pm
On a couple of occasions I have only replaced either the two fronts or two rears as there has been no need to change all four if only two are worn down
Post #74176 29th Jul 2011 5:18pm
Mikeyjd
Wales 2003 Range Rover SE Td6 Zambezi Silver
The only time it is essential on a 4x4 to have tyres with matching tread wear front and back is if a diff lock is used between front and rear axles. Imagine if one axle had tyres half and inch smaller in diameter than the other axle. Both sets of wheels would be rotating at the same speed but the more worn tyres would be covering a shorter distance with each rotation. This would result in tyres scuffing badly or excess strain on the drivetrain etc.
Hope that explanation helps with the theory. No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Previous LR- Disco 300TDi Auto
Post #74218 30th Jul 2011 1:48am
tommac22
many thanks fo rhte replies- will replace just the fronts for now then!
Post #74392 1st Aug 2011 9:57am
