Home > Maintenance & Mods (L322) > vehicle prep / checks for winter
speedymarktd6
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
preparing for the winter months all suggestions welcome
-check battery condition / voltage
-use silicone spray on all the door rubbers and shuts stops the rubbers freezing to the door
-check antifreeze level
-top up screen wash with the blue concentrate stuff stops the washer bottle freezing
-check tyres tread depth and pressures min 1.5 -2.0 mm
-wiper blades check for splits and operation do they sweep the whole screen and clear it
-check all levels and filling the fuel tank up removes moisture on tank internal walls that could freeze if cold enough
-solar powerd trickle charger is a nice luxury in winter just to keep the batery at its best when youve got the 4x heated seats on , heated steeing wheel on , heater on full and then when your out of the car the cab heater it all kills the batery
please add anything that ive missed onto no6 Range Rover
Everyone needs a hobby
Post #7436 26th Sep 2009 3:45pm
dan_uk_1984
I change over to a better quality thinner oil for the worst 6 months of the year, I find this stops the BMW rattle on cold startup if I change to 0W30 from 5W40. But then I'm anal about oil. Embarassed
Oh and Winter Wiper blades:
P/N: DKC500060PMD Think they cost aprox £40.00 Shocked
Summer Wiper blades:
P/N: DKC000040
Post #7440 26th Sep 2009 6:24pm
Regarding the solar battery trickle charger, make sure you plug it inot the socket in the boot as its the only one with power when ignition is off.
I taped mine to the inside of the rear side window. Discovery 4 HSE
1993 90 Tdi
Post #7444 26th Sep 2009 7:28pm
Dixy
2016 Range Rover Vogue SDV8 Loire Blue
Book skiing hollidays letters not necessarily in the right order
Post #7445 26th Sep 2009 7:46pm
ken
United Kingdom 2018 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
Get yourself some GoodYear MTR's Thumbs Up
Post #7447 26th Sep 2009 7:57pm
speedymarktd6
whats the difference between summer and winter wipers other than price ? On the subject of solar chargers does anybody have a suggestion or a link to one theyve used and can recommend Thumbs Up
the wranglers are on all year round with no probs at all Thumbs Up Thumbs Up onto no6 Range Rover
Post #7472 28th Sep 2009 4:35pm
dan_uk_1984
speedymarktd6 wrote:
what's the difference between summer and winter wipers other than price ?
Thicker rubber I think, helps shift snow and is more resistant to wear from ice.
PS, did you know that LR recommend using "Screen Cleaning Paste" Every time you change the wipers to avoid premature wear and also a grease build up
On the subject of solar chargers does anybody have a suggestion or a link to one they've used and can recommend:
Perhaps we could have a review of them in the review section we don't have Whistle
Post #7474 28th Sep 2009 4:45pm
I got my battery charger from Maplin. Discovery 4 HSE
1993 90 Tdi
Post #7510 29th Sep 2009 7:54pm
I got mine from a car at Sainsbury's ..........
The Wife's Car .......... Now what where you thinking ..... eh Exclamation Ner Ner Ner Ner
Post #7516 29th Sep 2009 8:34pm
GKP
United Kingdom 2003 Range Rover Vogue 4.4 V8 Cairns Blue
Re: vehicle prep / checks for winter
The legal minimum in the UK is 1.6mm in a continuous band throughout the central three-quarters of the tread width, throughout the whole of the circumference of the tyre. Be aware that RoSPA recommends tyres to be replaced when they get to 3mm as stopping distances in the wet can increase by over 35% at the legal limit of 1.6mm. Not sure you should be reading this bit.
Post #7526 30th Sep 2009 6:30am
Vogue
Got mine from Powerbee - Sunsei 170 - excellent quality made in the US :-
http://www.powerbee.co.uk/search.asp?numSearchStartRecord=6
http://www.sunsei.com/SE-170;jsessionid=0a...tegory=307
you need to be wary of output - the smaller units around 1.5 to 2.5 watts will only maintain and top up a fully charged battery. They will charge a discharged battery - but it takes weeks. If you want to charge a battery in a matter of days you need a huge solar pannel...
mine wasn't the cheapest but you do get a lot of accesories, its very well made and it has a 10 year warranty
Post #7534 30th Sep 2009 9:14am
