Home > Technical (L322) > Parking Heater Remote Control
Page 5 of 7 <1234567>
stu
its a shame really because the T91 is just the right size and shape for your pocket. the T90 is HUGE!!
may a T91 boot module is required just so we can use our slimline remotes.. Laughing Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #67275 6th Jun 2011 6:34pm
stu
well i think i must be a total idiot!!!.... Embarassed
i have bought two T91 remotes now, both Land Rover branded ones and both brand new, i can't get either of them to work with the T90 module i have fitted in the boot.
there are quite a few people on here seem to have got these newer remotes working with the T90 boot module, so where am i going wrong!!..... Sad Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #71723 8th Jul 2011 5:48pm
SAppie
I have both the t90 and the t91 remote, both work perfectly. here's the story........
I originally bought the t90 and tried all the methods mentioned to get it paired up and working, but no matter what I did, nothing worked. I assumed that it must be a faulty remote and left it at that for a while.
Then I noticed another thread pop up about the FBH remotes, so I ended up buying a t91 remote on eBay and thought I'd give it another go.
Upon receiving the t91, I tried all methods mentioned and nothing worked yet again, so I now had Both a t90 and a t91 remote that were useless.
One Sunday I decided that I was going to try my own method in resolving this, so...
1. I opened up the rear right hand side of the car by removing the carpeted flap.
2. Unscrewed and moved away the fuse box assembly in order to gain access to the t90 remote receiver which is screwed to the back of the fuse box assembly. It is labelled Telestart T90 - Webasto.
3. Unplugged the power plug to the receiver, waited about 10 seconds and then plugged it back in while at the same time pressing and holding the off button on the T91 remote for about 1 second then releasing it, all within the first 5 seconds of powering the receiver.
4. To my amazement, the remote now worked and pressing "on" turns the system on while keeping the Red LED on for a few seconds, and pressing "off" turns it off as expected while also lighting up the LED on the remote for a few seconds.
5. So I thought I'd try the same process for the older t90 remote and sure enough that worked too.
So I now have both remotes working perfectly, but I must say that the t91 is so much better because is half the size and fits perfectly onto my key ring.
My method was the only way I could get the pairing to work, no fuse pulling worked for me., Neither did disconnecting the battery terminal for a few minutes.... Strange but as I've said only above method works.
Obviously, you must be sure that you have the receiver installed in the first place, I used Microcat, which confirmed that the factory installed FBH and remote was installed, so previous owner must have kept the remotes.
Hope this helps, cheers Matt
Post #71843 9th Jul 2011 10:06pm
stu
thanks for that Matt, i will give it a try, nothing ventured, nothing gained... Thumbs Up Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #71845 9th Jul 2011 10:14pm
SAppie
I'm certain that you will come right Stu, let me know either way. Cheers
Post #71846 9th Jul 2011 10:28pm
stu
well, failed miserably again!!.. Sad
my T90 remote works, but as we all know they are massive and not really pocket friendly.
i have done as suggested by removing the power socket for the boot module. giving it a few seconds, then i left it for about 20 mins and still nothing. i just can't seem to get the t91 remotes to pair up with the RR.
i think i may have to speak to my local stealer and see what they say. Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #71881 10th Jul 2011 12:21pm
SAppie
hi stu, i'm sorry to hear that, the only difference is in our model year, mine is the 2007MY, but I thought that they used the same Webasto telesync T90 module....???? who knows????
Post #71900 10th Jul 2011 5:20pm
stu
yes you would have thought it was the same module. i can't remember who it was, but someone said to me that the T91 remotes can be a bit of a pain sometimes to program. guess i have that one!!..
never say never though, i will keep on trying, as i said maybe a trip to the stealer may shed some light on the subject. Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #71902 10th Jul 2011 6:30pm
stu
well, sorry to start this going again, but after leaving things for a while, it is still praying on my mind!!
so i had the FF booked into the dealer today, to get the speed locking turned on and the lazy seat thing as well. i asked them to program the T91 remotes while the testbook was plugged in.
still no joy, the techy guy couldn't get them to code and said that these are for the newer MY vehicles!!
well i can't understand why i can't get my remotes to work. i have done everything everyone else has done and still no joy.
i have the older T90 remote which still works a treat, but i would really prefer the newer T91 ones as they will fit in your pocket better...... Sad Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #73931 27th Jul 2011 6:08pm
stu
does anyone know where the heater fuses are? by this i mean the actual fuse block for the heater itself, not either of the car fuse boxes.
it's the only thing i haven't tried and it's what they suggest in the webasto instruction guide i downloaded. Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #73973 28th Jul 2011 5:33am
stu
right then, for starters, i would like to stand up in public and shame my self!!!... Embarassed Embarassed Embarassed
after all this time and plenty of huffing and puffing and whinging about things not working, i eventually did the very unmanly thing of downloading the Webasto handbook and actually reading it... Shocked
it all becomes clear after reading the instructions!! i decided that the batteries in my remotes were both on their way out as i had amber lights when the buttons were pressed. (why did the dealer not know this??? when he took £50 from me last week??.. Evil or Very Mad )
anyway, new batteries fitted, pulled the fuse and hey presto two working remotes, well sort of.
i have read the instructions and how to change from blower to heater etc, but i can't seem to get the light to change from green to red.
what i have on both remotes is a green light when i press on and a red light when i press off.
could someone with the newer T91 remotes please comfirm their LED colours when pressing on and off and if they can change between heat and cold by pressing both buttons together, twice within one second as per the instructions.
at last...progress!!... Laughing Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #74548 2nd Aug 2011 8:35pm
SAppie
Hi stu,
SOunds like you cracked it at last..
I believe that the T90 webasto unit that we have installed, will only allow off and on via the remote, no other functionality is available. Perhaps the newer 2010 MY onwards has more functionality????
If the outside temperature is below 16C then it activates the FBH and warms the interior, but if abov 16C then it simply activates the fans to remove the heat from the interior.
I have exactly the same as you, with red and green LED for off and on.
Cheers
Post #74631 3rd Aug 2011 5:13pm
stu
SAppie, thanks for your reply. yes at last i have got there. what you are saying about the lights etc sounds good to me. Funny though, because i have the older T90 remote as well and it lets you switch between hot and cold, and choose how long you want it to run for.
well that's progress for you.. Laughing
i am just happy that i've got there in the end. Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #74646 3rd Aug 2011 8:12pm
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
does anyone know which is the fuse in a MY11 ?
in the glovebox fuse compartment, 59 is a spare. The handbook doesn't assign a fuse to the FBH.
Post #84860 1st Oct 2011 7:54am
stu
are you sure you have all the bits and pieces for the parking heater fitted? the aux heater is a standard fit if i am not mistaken, but the parking heater receiver is an upgrade. Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #84863 1st Oct 2011 8:55am
