Home > Maintenance & Mods (L322) > Lowering 06 FFRR SC
Lowering 06 FFRR SC
Hi guys, anyone know an easy way to lower a facelift 06> RR please? Easily lowered my 04 TD6 using T4 but it would seem that 06> is now IDS and its not as simple as the early model... Bow down
Post #74722 4th Aug 2011 11:10am
there are companys on pistonheads and ebay that sell lowering kits..
http://www.pistonheads.com/sales/1345338.htm
http://www.ebay.co.uk/itm/Range-Rover-L322...1c1da11fe5
Post #74723 4th Aug 2011 11:18am
SteveMFr
Site Sponsor
Please see my post on RR.net for now. I've already been in touch w/ Martin (site admin) for commercial posting rights - will do an extensive post here as soon as I can.
Lowering links are... primitive Cool
http://www.rangerovers.net/forum/viewtopic.php?f=2&t=46826
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #74743 4th Aug 2011 2:22pm
+ = Low as you can go! Thumbs Up [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #74754 4th Aug 2011 4:32pm
JustinP
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
Rolling with laughter Rolling with laughter Rolling with laughter
Gone - Range Rover Supercharged 2006
Post #74758 4th Aug 2011 5:14pm
pretlove
steve how much are you doing these systems for in sterling and what options did you end up putting on them "RANGEISM WILL NOT BE TOLERATED"
Post #74784 4th Aug 2011 7:25pm
My lowering kit is about £10000000 an luckily I've managed to adapt it to cover a lot of stuff not just lowering. I'm sure you will agree it's the best tool anyone should carry in a FFRR!  [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #74788 4th Aug 2011 7:33pm
interesting read here..
Post #74793 4th Aug 2011 7:37pm
pretlove
i read that stan i just couldnt be bothered to read all the pages to find out what they ended up putting into the system and how much it would sell for in £££ "RANGEISM WILL NOT BE TOLERATED"
Post #74798 4th Aug 2011 7:45pm
Wink
Post #74800 4th Aug 2011 7:48pm
pretlove
Embarassed I know im a lazy git Confused "RANGEISM WILL NOT BE TOLERATED"
Post #74811 4th Aug 2011 8:02pm
so there are 3 units for the diy'er , the faultmate which is very expensive, the RAC which is still in development and the one from steve....
i would like to be able to play with the ranges settings so i brought the RAC but i'm still waiting for it to be updated..
Post #74816 4th Aug 2011 8:09pm
Reformed
Does the RAC all comms adjust the height? I have not played about with mine to much yet. Reformed
Post #74844 4th Aug 2011 9:32pm
it does have the settings for this but its on the expert part which i need guidance..
Post #74848 4th Aug 2011 9:43pm
SteveMFr
Site Sponsor
At least this means that the device would be well suited to you. You need nearly no instructions and it is quite intuitive. Razz
Summarized very quickly (just for you Cool ):
- the IIDTool is the full fledged diagnostic system. At the moment the IIDTool does fault reading and clearing in all systems and has very extensive component testing/live data and programming capabilities for the EAS (better than the OEM T4 and IDS systems the dealers use actually). We will be adding numerous systems later this fall and eventually hope to have a system that is better than all other systems in its capabilities - and much easier to use/more portable/and (above all) much faster. You can clear a fault in less time than it takes to boot the computer on all the other systems. And all beta buyers will be updated for free (postage charges will have to be paid but the unit is barely more than the size and weight of a box of matches).
- the EASControl is designed as a very advanced lowering/raising module. You reset the heights in the EAS ECU. And on your RR, you can reset the heights individually - that is off-road +20mm, standard -10mm, and motorway -30mm. This capability will be added for later ffrr's and the RRS/D3 this fall as well. Diagnostics is limited to fault read/clear. Same here too, btw, betas get updated for the cost of postage.
Here's another short bit to read - just read my post actually. http://www.rangerovers.net/forum/viewtopic.php?f=8&t=46827
And for the lazy couch potato in you, grab a lager and look through these (in no particular order):
Activation/unlock
Entering/navigating the menu
Fault clearing IIDTool
Changing height settings EASControl (works on the IIDTool as well)
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #74854 4th Aug 2011 10:02pm
