Home > Maintenance & Mods (L322) > Wheel and Tyre options
supershuttle
I've searched the WIKI to no avail and also googled and got conflicting advice.
I have a 2007 3.6 TDV8 running standard 19" wheels however I like the look of 20" wheels and so when the tyres are due I may well change as there are plenty of "sets" on eBay - this gives rise to a couple of questions.
1. What will fit comfortably under the arches.
2. Will the fatter wheels from a sport fit.
3. If I get bigger wheels do I really have to get 5 or is it OK to retain the 19" spare as a get me home measure given the actual rolling diameters will be pretty close.
4. Are there settings that need changing on the car if larger wheels are fitted or is that a myth.
I'm sure that this sort of stuff is on here but I'll chance a bit of abuse by asking again.
Thanks all
Thumbs Up Geoff
Post #75025 6th Aug 2011 1:52pm
1/ 255x50x20's
2/ Yeah they will just slightly different offset ( sure scarey runs with them just now)
3/ No the rolling radius will be the same
4/ No
No doubt someone will come along and give you a more techie point of view Thumbs Up ====================================
Post #75027 6th Aug 2011 2:06pm
what the grand master said... Thumbs Up
Post #75034 6th Aug 2011 3:43pm
Emperor Mong
United Kingdom 2019 Range Rover Autobiography 2.0 PHEV Loire Blue
I have been thinking about a set of winter and/or off-road tyres.
When I have looked at the offroad tyres, it would seem difficult to find anything with the correct speed rating (W for the 4.2S/C, IIRC).
What do others do? Ignore it (insurance issue?).
Post #78298 30th Aug 2011 6:02pm
"Uninformed Answer"
Don't know why speed rating is an issue with insurers. If the legal limit in this country is 60/70, if anything goes wrong (e.g. accident) and you are going faster than the indicated limit, your insurers will not pay out anyway. So if an "offroad/winter" tyre is rated at anything above 70 then I can't see a problem. However, if you regularly make use of the Fuhrer's autobahns, things might be different.
I fitted General Grabbers as my "winter set" on 18" rims, and never get close to the speed rating, plus mysummer 20" wheels have tyres that cost an extra £125 each! For a speed rating I will not go at nor the car can do! .
Post #78304 30th Aug 2011 6:22pm
the speed rating isnt that important but the load rating is....
Post #78305 30th Aug 2011 6:26pm
allycraven
Just remember if going for the wider 20" RRS wheels to get them shod with 295/45's or 275/50's as the more usual 275/40's look a bit silly in the bigger FF arches (have them on mine until i can justify changing) and are also a bit harsher on bumpy roads. Much closer to stock 255/55 diameter as well.
Post #78364 30th Aug 2011 9:30pm
Googsy
Having bought at least 5 sets of stormers with tyres for my Discovery I would advise you stick to the geniune RR wheels and recomended tyres. There are lots of copies out there some do not carry the correct load index etc. I too am tempted by the look of the 20's when my tyres wear out but if you fit 20s it definetly makes for a harder ride which I do not want to compromise. I do however love the look of the 20's. Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #78387 30th Aug 2011 10:29pm
Emperor Mong
Joe90 wrote:
"Uninformed Answer"
I guess I ought to talk to my insurance co about it. I personally agree with you - not going to be doing 100mph+ on winter tyres (or summer ones for that). However, I do worry that they may use any excuse...
Where does one find the load rating?
Post #78422 31st Aug 2011 9:23am
the load rating is after the tyre size and before the speed rating..
Post #78428 31st Aug 2011 9:36am
