![]() | Home > Maintenance & Mods (L322) > 2002-2006 Key into Flip Key |
I know there have been several variations on this theme, but would like to gather some clear and concise details on what is involved.
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3926 ![]() ![]() ![]() |
Let me know how you get on. I also would like to get rid of the old style key, particularly as I am unlucky enough to have a 2007 with the last of the old keys. Geoff |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
Hmmm, I only got one key when I bought the car so is this a cheaper way of getting a second key as well, without going through LR ? If so just need to find a suitable locksmith in the Winchester area. .
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2947 ![]() ![]() ![]() |
The only problem with buying new keys from the USA ( as I found out to my cost) is that they operate at different frequencies. I bought a brand new, unused one off a seller and had it cut by Timpsons. I went through the pairing procedure several times, with no joy. Opened the doors manually no problem, but I couldn't get it to work electronically. It fitted the ignition barrel but wouldn't release the steering lock.
You are correct - you have to order the right frequency.
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 ![]() ![]() ![]() |
I'm currently working on TETRA handsets ![]() ![]() Gone - Range Rover Supercharged 2006 ![]() |
Stryke Member Since: 16 Nov 2010 Location: UK Posts: 262 ![]() ![]() ![]() |
Can you tell me where you found the pairing procedure? Thanks. |
The Workshop Manual:
pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865 ![]() ![]() ![]() |
very intresting i think ill have to get one ...keep us posted please dan on how you get on "RANGEISM WILL NOT BE TOLERATED"
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1527 ![]() ![]() |
Cool ![]() |
Thanks for that Dan.
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
So the only thing needed is the new blade cut and the transponder coded? Where can the transponder be coded? I've got all the bits to change mine to long BMW key and a flip case to suite but this option looks a lot better so long as codeing the transponder doesn't cost a fortune! [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
The transponder is included as per the info on that website I think I will confirm in a few weeks when it arrives |
Dan,
