Home > General > Laminated Glass side windows?
The dent repair chappy is here this morning, he looked at the crease I have on the passenger door, wound the window down and said he can't touch it cos the side glass is laminated and they crack so easily if he tries to get a rod down the window.
If you wind down your front windows, and look at the glass edge, does it have 2 layers like mine? Was this standard, are they all like this?
So, no easy way to fix the dent afterall! Big Cry Discovery 4 HSE
Post #7530 30th Sep 2009 9:45am
Yeah, LR do it for Sound Proofing ............ Thumbs Up
Post #7531 30th Sep 2009 9:52am
Vogue
Yes, Mick is right - pretty sure it was only from 06 MY onwards.
Adam, just a thought but some paintless dent repair chaps will tackle a dent if they can drill a small hole in the door frame using a hole cutter to give an alternative access route - simply plug it with a rubber grommit - think it was 1/2" or 3/4". I had this on another vehicle where there was no access to the rear of the panel - mind you it was 15 years ago when dentmaster were in their infancy...
Post #7532 30th Sep 2009 9:55am
Vogue, this is what he's going to try, the hole will be underneath the inner door seal and therefore invisble. Discovery 4 HSE
Post #7533 30th Sep 2009 10:05am
RRVSE
United Kingdom 2013 Range Rover Vogue SDV8 Corris Grey
I've got the laminated glass on my Sept 06 RR VSE. I take it the likes of Dentmaster can't use their vacuum system to suck out the crease then, too long etc. Steve
Main car : FFRR L405 Vogue SDV8
Other car : Vauxhall Lotus Carlton
Past cars : FFRR L322 Vogue TD6 SE (Sept 2006 MY07) ; LandCruiser SWB ; 4-Runner ; Supras; XJS V12 LeMans
Post #7600 5th Oct 2009 1:03am
No don't think so... Discovery 4 HSE
Post #7602 5th Oct 2009 9:03am
