Home > Technical (L322) > Td6 cutting out
ben2012
2005 Range Rover Vogue Td6 Buckingham Blue
Td6 cutting out
Ive been having a bit of a problem with my 2005 facelift td6 for a few months now, parts have been changed but it still intermittently plays up, I've had a new fuel pump, fuel filter and sensor that fits on top of fuel filter fit,as air was getting into fuel system, (you could see air bubbles in clear pipe going into engine). Ecu was showing up loss of fuel pressure, all been fine for about month or so then on Saturday driving at a steady pace up a small hill and everything just cut out! No spluttering or anything it just died, had it on machine again and nothing showing, anybody got any ideas?
Many thanks
Ben
Post #75520 10th Aug 2011 1:39pm
Which fuel pump did you change?
Post #75531 10th Aug 2011 3:56pm
ben2012
it was one at the rear of the car not 100% sure but i know it didnt take long to change, it just seems strange how it works fine then all of a sudden stops!
Post #75564 10th Aug 2011 9:25pm
Mikeyjd
Wales 2003 Range Rover SE Td6 Zambezi Silver
How steep was the hill and how much fuel was in the car? No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Previous LR- Disco 300TDi Auto
Post #75566 10th Aug 2011 9:28pm
Might be wrong but i think diesel's have 2 fuel pumps. A low pressure and a high pressure. Think the one in the boot is the low and then somewhere else is the HP for supplying the cyclinders. that might be the one causing the problems? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #75570 10th Aug 2011 9:31pm
ben2012
it wasnt that steep and if anything it was leveling out when it cut out, their was probably about halfway between empty and a quarter of diesel
Post #75571 10th Aug 2011 9:32pm
Page 153 of the workshop manual. if you dont have it there is a link in the wiki. sorry dont know how to attach the pdf image
workshop manual: http://www.landroverweb.com/Pdf-files/Manu...0Rover.pdf
just having a read about the TD6 an bloody hell the fuel is at 1350Bar!!!! [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #75572 10th Aug 2011 9:38pm
Mikeyjd
Just a thought, as a faulty low pressure pump would likely show up if the fuel level was quite low. One pump moves the fuel from the tank to the engine area. The other pump squirts the fuel into the engine.
Old Discoveries used to have a very noisy mechanical lift pump. I spent many years listening to that racket Laughing No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Post #75573 10th Aug 2011 9:45pm
Check the diesel cooler in the engine bay is free from muck and leaves
Post #75574 10th Aug 2011 9:46pm
ben2012
just been looking at the workshop manual link posted earlier, and i think the secondary fuel pump was the one replaced, which is the other pump you suggest i look at? and how do you clean the fuel cooler?
thanks ben
Post #75576 10th Aug 2011 10:01pm
The other fuel pump is in the fuel tank.
Fuel cooler is on near side in engine bay next to the filter. Remove the trunking and you will see what looks like a small radiator, clean out any debris that has accumulated with a vacuum cleaner and small brush
Post #75578 10th Aug 2011 10:11pm
