![]() | Home > Technical (L322) > Coolant Loss |
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 ![]() ![]() ![]() |
has the expansion tank cap given up the ghost? do these not have pressure valves built into them?
Nod 1 Member Since: 05 Oct 2009 Location: Burnham Posts: 20 ![]() ![]() ![]() |
I hope so. Thanks for your response |
pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865 ![]() ![]() ![]() |
sounds like the cap what number is on your expansion cap? "RANGEISM WILL NOT BE TOLERATED"
Just checked and it is 200. I am just off to get cap, expansion box and sensor. Will let you know later |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
If you are getting a puddle under the car that's a good thing. If you were loosing it and didn't know where it could have been a HGF. But yours sounds quite easy to sort. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Just been and got cap and it has 140 stamped on it. Queried it with the Parts guy and he said it was correct one. Anyone any ideas why the change from 200 to 140 ? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35829 ![]() ![]() |
as far as i can remember , the 200 is for petrol and 140 is for diesels.....
i thought the v8 petrol was meant to be 200 ....as if i remember right someone else had this problem before and theres was due to the incorrect cap "RANGEISM WILL NOT BE TOLERATED"
If yours is a petrol and you put a 140 on you WILL loose water. The petrol system is pressurised higher than the diesel. This was covered a few months back. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
and maybe this is why the coolant is more prone to being lost.. |
The original I took off had 200 stamped on it. The one i was given by Lancasters had 140 stamped on it. I have just queried this with them and they say there is only one part number....! Any suggestions please |
they have given you the wrong part...i'd go somewhere else.. |
they sell the caps on fleebay just give them theres back and get one from there "RANGEISM WILL NOT BE TOLERATED"
I would put money on it! Any little gap and it comes out. Think that's why BMW designed the stupid hose's with the stupid clips instead of jubilee clips. If the caps are anything to go by there jet be quite a difference. 140psi(9.5bar) compared to 200psi(13bar). Obviously these are the relief pressures but it's a big difference [img]http://www.fuelly.com/driver/rob2529/range-rover[img/] 04, 4.4V8, Vogue Oslo Blue with LPG. "You can sleep in your car, BUT you can't race your house!!!!" If something can't be fixed with a hammer....... You have yourself an electrical fault! |
