![]() | Home > Off Topic > Seen on the way to the takeaway |
Fox Member Since: 02 Apr 2010 Location: Essex Posts: 2313 ![]() ![]() |
Looks fun(ish), but avoid any fast corners or very bumpy offroading... |
That looks more like an Ice prepped vehicle than a mud plugging offroader... |
Bet it doesnt handle too well at speed! |
I bet it tops out at about 80-90ish anyway |
I got my first speeding ticket in my classic, on the M3. Good times. They were limited to 115. Nice to see the RR has got a whole 15mph faster ![]() ![]() |
1mph per year, its almost as bad as the interest rates! |
BrianC Member Since: 15 Apr 2009 Location: central belt Posts: 1429 ![]() ![]() |
what makes you think its on a defender chassis ? |
Agreed, most things find their way onto a Range Rover chassis... ![]() |
dantheman Member Since: 02 Feb 2009 Location: North: Lancs Posts: 477 ![]() ![]() |
I've seen enough Defender chassis' in my time and looked like one whilst passing (axles also) - but hey, I might be wrong. |
How would you differentiate between a Defender Chassis and a RRC Chassis considering they are pretty much identicle, including axles? The main difference would be if it was from an early defender it would have drum brakes? ![]() |
Between a Defender and RRC chassis Dan? If they are indeed that similar (which I wasn't aware of), TBH, passing at 15-20mph I wouldn't have the foggiest, then perhaps it wasn't... |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8064 ![]() ![]() ![]() |
RR that age is the same chassis as the defender, but has 100" wheelbase rather than 90 or 110.
the best donor car to use now is a disco 2 as its got better running gear/radius arms/watts linkage suspension etc .a bit of useless info but a land rover 90 has a wheelbase of 92.5" not the 90" that everyone asume's |
DeltaC Member Since: 23 Mar 2010 Location: Aberdeenshire Posts: 148 ![]() ![]() ![]() |
The chassis are more different than just length - crossmembers, outriggers etc. ![]() |
