Home > Maintenance & Mods (L322) > Car Detailing: How to achieve amazing results @ Home
Page 3 of 3 <123
nbunney
United Kingdom 2018 Range Rover Autobiography SDV8 Corris Grey
Censored my secrets out Whistle
Nick
Would e great to meet up and if you could get me some CLOTHS that would be great, as there is no costco near me to make it worth the trip.
Post #49004 5th Feb 2011 7:53pm
Mikeyjd
Wales 2003 Range Rover SE Td6 Zambezi Silver
What's the best for cleaning/polishing the black window pillars? Should they be waxed like the rest of the car? No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Previous LR- Disco 300TDi Auto
Post #69116 18th Jun 2011 12:58am
swast4
Great info, What is best for rubber floor matts ?
Adam
Post #76148 14th Aug 2011 10:00am
GregP
United Kingdom 2002 Range Rover HSE Td6 Adriatic Blue
I use autoglym vinyl and rubber care for the mats Thumbs Up FFRR TD6 HSE
Adriatic Blue with Parchment leather.
Post #76152 14th Aug 2011 10:12am
Can't find the Meguairs 3 Stage Paint kit on the Meguairs site. Can someone indicate the three products required? .
Post #123604 25th May 2012 12:05pm
bump? .
Post #123817 27th May 2012 12:12pm
twhincup
2004 Range Rover Vogue 4.4 V8 Zambezi Silver
this should help:
http://www.meguiars.co.uk/product/378/Step...t-Cleaner/
http://www.meguiars.co.uk/product/204/Step-2-Deep-Crystal-Polish/
http://www.meguiars.co.uk/product/207/Step...nauba-Wax/ 2007 3.0L Diesel VW Touareg SE
2003 4.4 LPG, Vogue, Silver
Post #123869 27th May 2012 11:06pm
5IMON
Woolite does wonder for leather-google it
Post #123877 28th May 2012 12:15am
OK just ran a test on bringing up a great looking finish (not on an FFRR just yet)
Last summer, I rattle can sprayed up one of the doors on my MG Midget (primer, nightfire red metallic (2 coats), lacquer (3 coats)). The finish wasn't all that glossy (hard to apply deeply enough lacquer without it running).
With nothing to lose, I took to the panel with some 1200 grit wet and dry (and water) and lightly sanded it down to a dull finish. Wipe off then attacked with the polisher and Meguiars Stage 1 Paint Cleaner. After going over once I wiped down then went over it again with the Stage 1.
Wow - talk about mirror finish!
Got even better after applying Stage 2 (Polish) and Stage 3 (Wax).
Nice to be able to try this out on something less important before tackling the FFRR with it, but its a great confidence giver. I have rust bubbles on my rear left wing that need sorting out. But could be used all over. Probably saves a lot of elbow grease, no need to clay etc. Depends on the paintwork you are starting with! If 1200 grit sounds too aggressive try 1500. Need a goodly amount of clear coat on your paint too Smile .
Post #175378 2nd Mar 2013 1:01pm
I've used 2000 grade emery paper on car paint work before polishing.
Certainly get a mirror finish. Thumbs Up
Not used it on the FFRR but there's time
Post #175382 2nd Mar 2013 1:22pm
vince
RRUK wrote:
The first thing a proper guy does is remove the handle as they need finger tip control (In fact this is the acid test of a pro when we try them out if they leave the handle on they are bluffing).
This needs to be taken with a pinch of salt....true in so far as machining whilst holding the handle doesnt give you the same finite control as holding the machine as if it wasnt fitted, but the D handle if left in place does allow you to put down your machine without it rolling over and picking up grit onto the pad Wink I dont have one fitted on my rotary as it doesnt tend to roll over, but have left it on on my DA for that exact purpose. I dont use it when machining though Wink
Vince - Pallas Auto Refinishing
Post #175521 3rd Mar 2013 11:29am
rar110
Having less and less time means the weekly Saturday routine for keeping our two cars clean is getting harder to fit in. I usually pressure clean, shampoo and towel dry. I also clay bar and wax every 6 mths. As the cars live outside I often have to give them a wipe over to deal with bird and bat droppings before they eat into the paint.
I've started to use a quick detailer spray which seems pretty good. It's not as good a result as the full routine but it's ok and a lot quicker. I will continue the full routine just not nearly as often. Buying detailing spray by the bottle is expensive. So I'm thinking about buying a concentrate which is about 1/10 of the price.
Has anyone had long term experience with using quick detail sprays generally and in particular with Chemical Guys detailer sprays? ______________________________
Post #384561 30th Apr 2016 12:52am
LROMAD
United Kingdom 2008 Range Rover Vogue TDV8 Stornoway Grey
A good tip for those thinking of using an electric( or air polisher.) To protect the edges /swage lines on panels,we use 3M fine line tape. Comes in 2 widths 3mm and 6mm .Carefully stick it ( raised ) areas before polishing.You can polish over it ,as you do the panel. Comes off easily.Available on e bay about £5 a roll/ 36 yds long.. Thumbs Up
Post #384569 30th Apr 2016 7:50am
Page 3 of 3 <123
