|  | Home > Technical (L322) > EAS pressures and compressor stuff |
| swast4 Member Since: 07 Jan 2011 Location: Wirral Posts: 69      | I'll try again
|  14th Aug 2011 3:01pm |
| swast4 Member Since: 07 Jan 2011 Location: Wirral Posts: 69      | And try again
|  14th Aug 2011 3:03pm |
| SteveMFr Site Sponsor Member Since: 22 Nov 2009 Location: Strasbourg, France Posts: 1641  | It would def be interesting to get the dimensions on a new ring as a comparison.
|  14th Aug 2011 3:53pm |
| swast4 Member Since: 07 Jan 2011 Location: Wirral Posts: 69      | The black bit the same length of motor is the air drier, basically a cylinder with silca gel inside, nothing complicated. there is a thicker pipe going back to the suction (spillback). There are 2 funky valves solenoids. One of them is a normally closed and open when motor is running (to stop system draining out and to enable compressor to be changed and I think the other one releases the air out of the system when lowing vehicle.
|  14th Aug 2011 4:19pm |
| Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470      | Nice one ad. Just saved me a job! [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
|  14th Aug 2011 6:10pm |
| SteveMFr Site Sponsor Member Since: 22 Nov 2009 Location: Strasbourg, France Posts: 1641  | Thanks Adam. That really demystifies things then. So the funky valves will be inlet/exhaust.
|  14th Aug 2011 10:18pm |
| swast4 Member Since: 07 Jan 2011 Location: Wirral Posts: 69      | I've just given the compressor to our machine shop in work to see what he can do.
|  15th Aug 2011 11:40am |
 Those were exactly the reasons I said that it would be interesting to have the dimensions of a new ring and to do a compression test. If the ring is not what's causing the problems with your compressor then it has to be either inlet or outlet side. On the P38 compressors, the reed valves (if they are called that - 1-way inlet/outlet valves) have been know to fail. Air filter clear? Is the 'funky valve' switching properly?   RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) | ||
|  16th Aug 2011 9:05am |
| swast4 Member Since: 07 Jan 2011 Location: Wirral Posts: 69      | Yeh I know what you mean but it means forking out £330 for an experiment. The inlet valve on the compressor looked fine with no damage or contamination. Also the inlet filter is just a round metal gause on the compressor. Not the funky witches hat tap thing.
|  16th Aug 2011 8:26pm |
| SteveMFr Site Sponsor Member Since: 22 Nov 2009 Location: Strasbourg, France Posts: 1641  | Hi Adam,
|  16th Aug 2011 8:42pm |
| swast4 Member Since: 07 Jan 2011 Location: Wirral Posts: 69      | Hi Steve,
|  16th Aug 2011 9:12pm |
| Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470      | That's interesting about flipping the ring over.  If only we knew what a new one looked like. My old compressor had a radius on the ring. Have you stripped your old/new compressor yet Adam? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
|  16th Aug 2011 9:57pm |
| swast4 Member Since: 07 Jan 2011 Location: Wirral Posts: 69      | Not got it yet, will experiment when I get it. That one of yours we havn't got a clue which way it was ? Is your cars stearing still good ? | ||
|  16th Aug 2011 10:00pm |
| Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470      | I took it off the first time I stripped it an never noted which way it was. We could test it both ways? Obviously work is busy then! Lol. Steering is amazing! [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
|  16th Aug 2011 10:08pm |
| Posting Rules
