![]() | Home > Technical (L322) > Tickover Query |
SGW Member Since: 09 Sep 2009 Location: Headcorn Kent UK Posts: 77 ![]() ![]() ![]() |
Welcome to the site, are you petrol or diesel.
If you have the 4.4 BMW V8 then I get the same issue very occasionally, interesting I get it whether running on LPG or Petrol...
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6383 ![]() ![]() |
At low speed manoeuvring does the ECU compensate for low revs when it needs increased power for the PAS? Discovery 4 HSE
Increased power should match increased load - so you should never notice the revs go up, but likewise you shouldnt notice them go down either. Unless something's going wrong with this calculation and that's why it goes screwy sometimes... |
Nod 1 Member Since: 05 Oct 2009 Location: Burnham Posts: 20 ![]() ![]() ![]() |
Hi.
Any sort of shudder often points to coil pack related problems. Check the rocker covers for oil leaks as the oil pools around the coil packs/plugs. Have you changed the PCV hoses yet? If not they will also be leaking oil all over the place by now.
Bet you wished you'd never asked! |
Hi Dan
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 ![]() ![]() ![]() |
how about cleaning out the idle speed control valve they get very gummed up ive cleaned loads on other makes of cars |
Thanks I will give that a go at the weekend |
Nigel, It may be worth seeing if any fault codes have been flagged up. James French could check this for you, maybe one of the temp. senders is faulty.
ken Member Since: 22 Aug 2008 Location: On another forum Posts: 936 ![]() ![]() ![]() |
I Read this as Tixover Quarry |
Wondering if this was ever resolved?
Hi Dan, is this just on start up or all the time also is it the same on petrol and lpg.
