![]() | Home > Technical (L322) > Door Locks and SatNav Issue |
Have you checked your spare wheel well for water? Any water in that area means your nav unit may have got wet at some point. Are you still running the old Mk3 nav or have you done the mk4 upgrade?
neilmcm1975 Member Since: 18 Aug 2011 Location: falkirk Posts: 4 ![]() ![]() ![]() |
Thanks had a quick look and found water in the spare wheel well , it's the mk3 system I have , any ideas where to start looking for where the water is coming in.
It tends to make its way in around the near side rear window due to a poor seal.
had a quick look can't see anything could you send me a link to the fix .
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35803 ![]() ![]() |
the info you need neil is in the wiki..... http://www.fullfatrr.com/wiki/Rear_Water_Ingress
Got the water leak fixed it was coming from the boot seal and running down the pillar , new seal fixed it also fitted the water shedder/bag. The front door is now fixed not sure how but had the door card off and was looking for anything obvious put the door back together and it started opening and closing with the key .
whip the door card off that one as well neil, might be a loose connection.. ... - .- -.
