![]() | Home > Technical (L322) > Strange speed restriction problem |
GJOB Member Since: 24 Oct 2010 Location: Northants Posts: 131 ![]() ![]() |
I take it that's a no then |
Sounds like fuel starvation to me. The bit about lifting off and then being able to drive through it suggests the brief lift allows fuel pressure to build back up. Might be worth getting the high pressure pump tested, also the lift pump.
letsavit2 Member Since: 16 Oct 2010 Location: essex Posts: 854 ![]() ![]() ![]() |
you have a secondary fuel pump on the td6, these seem to go first. 2004 black Vogue TD6 |
Thanks chaps, I'll get that checked out. |
Replacement pump ordered, hopefully going to be sorted next week. Th warranty is picking up the bill, phew!! |
Got it back, all sorted but it had started bloody working again before it went in.
brumster Member Since: 23 May 2011 Location: Chislehurst Posts: 41 ![]() ![]() ![]() |
Loved my p38 but I wish I'd chopped it in earlier in favour of an L322. Stick with it. Definitely worth the hassle even with the teething probs! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35830 ![]() ![]() |
i agree with brumster, why have a boring car that works first time and nothing goes wrong with it, better to have a fullfat and battle your wits against it... |
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1055 ![]() ![]() |
It it's anything like the 530d (same engine), then after one pump goes, the other one will too, since it's been overworked to compensate for the failing pump.
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 ![]() ![]() ![]() |
I'd suggest it's also worth checking the MAF. That can cause these sorts of problems. |
Thanks chaps, my neighbour cowers when he see me these days, I just give him the keys, his fault for being a LR service manager |
