![]() | Home > Maintenance & Mods (L322) > 2002-2006 Key into Flip Key |
HUGI Member Since: 23 Oct 2010 Location: Jona-Rapperswil Posts: 244 ![]() ![]() ![]() |
they often want to sell bigger quantities.
I asked them who their regional dealers are, so I can buy from them instead - they didn't reply.
3R10 Member Since: 17 Oct 2009 Location: Paris Posts: 324 ![]() ![]() |
hey dan, check this out
Stryke Member Since: 16 Nov 2010 Location: UK Posts: 262 ![]() ![]() ![]() |
Ok, so say I get this key, get it cut... Does the dealer have to code it? ![]() |
It's not that key - that ;s just the case. No internals :'( |
BrianC Member Since: 15 Apr 2009 Location: central belt Posts: 1429 ![]() ![]() |
is this what your after ? http://www.ebay.co.uk/itm/Land-Rover-Range...19c8661ccc |
pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865 ![]() ![]() ![]() |
i think the ignition is in a differant place on the 2007 model so i doubt that would be any good "RANGEISM WILL NOT BE TOLERATED"
Fraid not, already checked that out... Getting the key to turn in the lock is never the issue, or even unlocking the doors. The issue is the transponder chip programming. I've phoned a lot of companies over the last week or so who say they can "clone" the transponder chips, but whenever you say "Range Rover" they have all said they cant do them ![]() If you were prepared to sacrifice your original key you could get a flip key, but it's a bit risky. I "think" the immobiliser/security module is different with the flip keys, but haven't had time to 100% verify this. ![]() |
id be willing to scrifice one of my keys to try this out ....so what would i need dan in order to do it "RANGEISM WILL NOT BE TOLERATED"
oodathort Member Since: 01 Nov 2010 Location: just there Posts: 191 ![]() |
I did this using the BMW diamond key and a flip case of ebay |
I looked at that option - however it's never going to look great. It's still a BMW key inside a cheap aftermarket case. Personally I prefer the idea of the real deal. Otherwise I don't see much point myself. ![]() |
Well to add to this i am keeping my eye on the bay so as to buy a cheaper newer style key, maybe even a disco 4 one, and an older key that still works and mix and match both of them to get a nice new flip key.
i have tried several times with a few flip style keys and they will not programe to the bmw cars,i.e open and close the doors, the bmw diamond key will but you are back to the same type of key, i do know some one who can do the transponder chip, not cheap... but you could use the one from your old key,they just fall out, the key cutting is not a prob..back to programming it to open and close, you will need a remote that can clone and copy the commands. i dont think removing the board from your old key and modding it will work they are to different.
jammyk Member Since: 12 May 2011 Location: Oxfordshire Posts: 17 ![]() ![]() ![]() |
All, when i purchased my car the spare key wasnt present. In the end the delares ordered my a new key and coded it. This new key was indeed a new style 'flip' key. As this was all done as part of my vehicle purchase i have no cost information.
