![]() | Home > General > TDV8 owners - what diesel ? |
Autobiography Member Since: 10 May 2011 Location: UK Posts: 926 ![]() ![]() |
Was told just regular diesel by the dealer for my 4.4TDV8. Get really good economy so wouldn't bother spending the extra 11p or so a litre. |
carlos50 Member Since: 03 Feb 2011 Location: North England Posts: 717 ![]() ![]() ![]() |
Thanks Autobiography, I was there at the pump so filled up today but I'm not sure I'd see much improvement in mpg, performance or refinement to he honest hence my post on here.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35811 ![]() ![]() |
dont know whether its been suggested but have a look and see if you have a dirty air filter.. |
I've checked the air filter, its a bit dirty but not black, it was replaced 2 years ago and approx 18k miles ago so I assume its still ok? |
its just that i replaced mine and the mpg went up a bit..worth a try especially after 2 years or take it out for a bit to see if it makes any difference....and i've tried different diesel suppliers with no difference found on my td6.. |
Tim in Scotland Member Since: 25 Mar 2007 Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland Posts: 2181 ![]() ![]() |
Superdiesel certainly isn't worth the extra! I used to run on Sainsbury's forecourt diesel but for the last 2 years have run almost exclusively on Shell Regular diesel - after burning 3 full tanks of the Shell my mpg had increaded from 26 to 29 and now I regularly see 31 mpg on my 16 mile drive into town. 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes |
I may try Shell after this tank then, I know my local Shell garage is more than Tesco but if I can hope to see a 10% increase I think it will be worth it. |
I never use supermarket Diesel. I used to use supermarket Petrol but after that issue a few years ago I haven't touched it since. I also seem to get better mpg on Shell/BP etc. |
Best thing you can do with a diesel is get some biodiesel mixed in a few 100 miles before its next service, this helps clean out all the gunge in the tank and the system far better than any performance diesel or additive IME and helps bring the car back in line with what it should be like. i'd reccomend putting no more than say 30 litres in to a tank and then topping up with normal diesel as each biodiesel supplier varies in quality from my own experience |
johnson1 Member Since: 30 Aug 2010 Location: South West Posts: 519 ![]() ![]() ![]() |
30 litres is too high according to the handbook and will damage the engine. See below:
5% is only there because all fuels need to be a 5% bio blend now so no matter what garage you go to its already got a tiny bit of bio in it but not enough to really clean your system out, even 30litres in a tank as big as the FFRR isn't too much really once diluted by another 74.5 litres... |
What would it do to your warranty though if you've gone 'against' LR guidelines and it messes up your engine? |
It would be flushed out after a few tank fulls after and it would have to be very strange for them to dip your tank to test what was in there. Also the dilution would be such that as you have had the car a while and if a remanent remains whats to say the previous owner hasn't done it?
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3982 ![]() ![]() ![]() |
You shouldn't need to worry about putting bio diesel in your fuel tank in a car that is under warranty, it's simply not necessary. The bacterial build up in diesel fuel tanks and fuel lines etc ie "gunge" takes a few years to establish itself far more than a normal warranty period. Just stick to "normal "diesel. If you feel need the need to chemically clean out your fuel tank just stick a 3 litre bottle of new vegetable oil in the tank every now and again when you fill up. Be prepared eventually to change the fuel filter if you do though the stripped "gunge" collects in it. Also works wonders at mot time in reducing exhaust smoke emmisions. |
