Home > Technical (L322) > oh no! idle squeal on V8 RR 2004 - only just bought it :(
Page 1 of 4 1234>
RR8701
United Kingdom 2005 Range Rover Vogue 4.4 V8 Java Black
Hi Guys,
I have tried to find a solution on this but I cant find a definite answer. at idle I have a slight squeal coming from the front engine area, as far as i can tell this is coming from the passange side and when I sprayed wd40 (i know i really shouldnt have) it stopped but obv did come back a day later
I have read up it can be tensioner pulleys or idle puilley but I really dont know if this would be the case it only has 64k on the clock and is a sept 2004 model.
any ideas guys ? i just want to make sure its not something serious or that i urgently need to attend to
ps. when i rev, it goes go away, its only at idle that the squeal happens
Post #77343 23rd Aug 2011 10:56pm
pretlove
fanbelt? "RANGEISM WILL NOT BE TOLERATED"
Post #77345 23rd Aug 2011 10:58pm
sounds like alternator noise..
Post #77346 23rd Aug 2011 11:00pm
RR8701
i dont think it could be the alternator as when i sprayed wd40 the noise went away, if the noise stayed i might have thought it was but then again i dont have much technical knowledge about this. but im learning
could it really be the fan belt ? are they not meant to last atleast 100k miles???
Post #77352 23rd Aug 2011 11:18pm
if you sprayed the wd40 onto the alternator pulley assembly then maybe .
i would a more selective spray and see what stops making the noise when sprayed..
Post #77354 23rd Aug 2011 11:24pm
RR8701
Ill get under the hood tomorrow and see if i can have a better look, its just so dam tight that you can barley see or reach lower down....
cheers again, ill let you know tomorrow what i find... any other tips for when i do have a look ?
Post #77356 23rd Aug 2011 11:29pm
a torch will help and spray little by little..
Post #77358 23rd Aug 2011 11:32pm
pretlove
take a cup of tea outside with you.....always nice to have a tea when working on your car......oh and its bonnet "RANGEISM WILL NOT BE TOLERATED"
Post #77360 23rd Aug 2011 11:35pm
RR8701
I got the kettle on timer already for tomorrow Razz ...
thats what happens when you watch too much american tv. haha
Post #77362 23rd Aug 2011 11:42pm
pretlove
Rolling with laughter Thumbs Up "RANGEISM WILL NOT BE TOLERATED"
Post #77373 24th Aug 2011 5:45am
I have had this on a few I think its the fanbelt pulley. Goes away with 3-1 spray or WD40 but only on a temporary basis....
Post #77381 24th Aug 2011 7:43am
I've had this for weeks also had it about two year ago it was the fanbelt pulley that had to be replaced so now I don't bother with it I just turn the tranny up and mine is only sitting at 55k miles plus my brother might be buying it for £12k so he can get it sorted if he buys it Laughing
Post #77383 24th Aug 2011 7:53am
RR8701
I'm not fussed about the squeal tbh I can use 3 in 1 spray or even I heard some chalk used on violins works perfect. I'm just thinking if it is the pulleys would it be best to get the culprit fixed or is it possible for it to ever break? Or does it essentially just get noisier and noisier.
Lollllll make sure u give it a squirt of wd40 before you sell it to him. "as good as new" Twisted Evil
I'm going to ask a dumb question: what do you mean turn the tranny up
Cheers guys.
Post #77388 24th Aug 2011 8:25am
tranny = transistor radio
Post #77390 24th Aug 2011 8:34am
RR8701
Ahhhhhhhhh hmmmm feel silly now
Good job I've got harman karden then
Post #77391 24th Aug 2011 8:45am
Page 1 of 4 1234>
