Home > Technical (L322) > oh no! idle squeal on V8 RR 2004 - only just bought it :(
Page 2 of 4 <1234>
harman karden sounds like ice cream..
Post #77393 24th Aug 2011 8:46am
You must have the cheaper version of Harman Karden, coz i have Harman Kardon Laughing Laughing
Post #77396 24th Aug 2011 9:11am
RR8701
United Kingdom 2005 Range Rover Vogue 4.4 V8 Java Black
This is where I will swiftly come in with the excuse that I was on my iPhone on the bus this morning on the way to work :p
Post #77402 24th Aug 2011 10:10am
...and i only copied your spelling ... Ner Ner
Post #77403 24th Aug 2011 10:11am
Tim in Scotland
Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland
2010 Range Rover Vogue TDV8 Stornoway Grey
Mick you keep a tranny in your car............. Shocked
Doesn't that disturb the kids and neighbours you keeping a guy in drag in your car? 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #77408 24th Aug 2011 10:28am
trust you to think of the 'alternative' meaning tim.... Laughing
Post #77409 24th Aug 2011 10:30am
dan_uk_1984
Have you considered that it may just be that the belt is worn? If it has a frayed edge it may be rubbing on something.
When were the belts last replaced? Or as suspected it could be a pulley failing. The pulleys are cheap to replace, the idler pulley on mine disintegrated on the M5 200 miles from home - I wish I'd had it replaced when I first noticed the noise.
Post #77411 24th Aug 2011 10:43am
mzplcg
scarey wrote:
tranny = transistor radio
Or summat else. depending on where you happen to be in the world......Thailand for example. Whistle Whistle
Post #77416 24th Aug 2011 11:21am
RR8701
Well it diddnt even cross my mind purely on the basis that these belts are meant to last atleast 100k however i have read that some people have changed them well before this limit. could it really be worn ? I am assuming we are talking about the same belt ? the serpentine belt ?
I dont know when the belt was replaced last I have only just bought the car but it was serviced at 60k from land rover main dealer and then smaller oil service was done at a local garage at 64.5k just before i bought it but i dont know much history other than that, it now has 65k on the clock.
thats the thing that is bothering me, i dont want to ignore it, if it can cause me more trouble later. i really wish I could do this type of work myself, even if I had a mechanic friend or a person in the know to help me... lol first time ive had a v8, i love my cars but made the unfortunate career choice of becoming an accountant Censored
Post #77417 24th Aug 2011 11:30am
pretlove
did you not check the fanbelt .... Confused id say it is a good chance its that or as said maybe the pully "RANGEISM WILL NOT BE TOLERATED"
Post #77461 24th Aug 2011 4:34pm
BrianC
i had this when i first bought mine ,the noise would go away after 5 minutes.
turned out to be the tensioner
Post #77464 24th Aug 2011 5:06pm
JustinP
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
My SC developed a squeak which was fixed by a new main drive belt pulley and belt.
Gone - Range Rover Supercharged 2006
Post #77468 24th Aug 2011 5:44pm
algt2
Scotland 2006 Range Rover Vogue 4.4 V8 Zermatt Silver
Had the same issue at idle but over a month or so it got worse and ended up present all the time, turned out to be the tensioner, got it done and new belt fitted at the same time cost about £200 if i remember rightly.
Post #77469 24th Aug 2011 5:49pm
RR8701
I had a look at it and it seemed ok. Any proper way of checking it?
I'm on my way home now after another exciting day Yawn
Post #77473 24th Aug 2011 6:17pm
trickle a little water on the belt whilst the engine is idling, if the belt is the problem it will temporarily quieten whilst wet. Do not be tempted to spray with WD40 or similar
Post #77476 24th Aug 2011 6:29pm
Page 2 of 4 <1234>
