Home > Technical (L322) > oh no! idle squeal on V8 RR 2004 - only just bought it :(
Page 3 of 4 <1234>
pretlove
also check the belt for cracks and wear ....you may have to take it off to do this "RANGEISM WILL NOT BE TOLERATED"
Post #77477 24th Aug 2011 6:40pm
RR8701
United Kingdom 2005 Range Rover Vogue 4.4 V8 Java Black
how would i take the belt off without having to take off the fan etc etc
Post #77483 24th Aug 2011 7:48pm
RR8701
well guys...
i boiled the kettle, made myself a nice cup of tea ....
open the 'bonnet' of my RR ...
started up that V8 (got to love it) ........ squeeallllllll squeaallll Big Cry
poured some water on to the fan belt near the passanger side and all i could here was the rumble of my v8 Razz ... so it looks like the obivously culprit is that my belt is F****D Censored
I will want to work on this RR as much as possible myself and id really apprieciate if someone could point me in the direction of where I can get guidance on changing this myself. I suspect this is a comfortable job to do for a novice, I seen my dad do it on a jaguar v8 before but that was almost a decade ago...
Post #77498 24th Aug 2011 10:36pm
You would be as well changing both belts whilst you're at it. Release the tension on pulley number 5 and slip the belt off, then remove the tension on pulley number 7 and slip the second belt off. Refitting is reversal.
Post #77500 24th Aug 2011 11:23pm
RR8701
Holly Cow !!! Shocked Does this beast have two belts, I assumed it was one from a different diagram I seen ..
hmmm right i see, yeah I would certainly change both if was doing the work to get to one anyway however how would i even access the pulley's theres no way unless I took the fan out or does everyone generally jack the RR up and work from the bottom ?
Cheers
Post #77501 24th Aug 2011 11:32pm
pretlove
i thought it was your belt ...any way you can get to it either way from the bottom or the top if your not very tall like me get a crate Laughing "RANGEISM WILL NOT BE TOLERATED"
Post #77502 25th Aug 2011 12:30am
Vogue
if you have a squeak, get it sorted. The chances are it is the tensioner pulley or idler puller. Mine was - the bearing was on the way out.
Literally the pulley seized and was worn down to nothing by the fan belt, the belt ended up running on just a steel arm, the pulley had gone - a few more miles and the belt would have frayed, snapped and stranded me.
The squeak is the bearing starting to run dry, it is only a matter of time. A £250 main dealer bill can soon escalate with recovery charges plus the inconvenience.
Post #77553 25th Aug 2011 4:01pm
RR8701
Could it really still be the pulleys or tensioner. What I dont understand is that if I have poured water on the belt and it stops squeaking then it must be the belt surely? If it actually was the pulleys or tensioner would it not still make a squeal regardless of water or am I wrong?
Cheers
Post #77570 25th Aug 2011 6:34pm
It's not a big job to change the belts, change them first and see if the squeal goes away
Post #77573 25th Aug 2011 6:42pm
RR8701
Yeah sounds like a plan. I'll change the belts first. Any steps on how to do this?
Post #77575 25th Aug 2011 6:47pm
Take it along to John's (47p2) garage and he'll do it FOC , really really kind guy …. Thumbs Up
Post #77577 25th Aug 2011 6:49pm
As above, release the tension and remove the belt. The tensioner will have a bolt at one side which is for releasing the tension, I've not worked on a V8 engine so cannot tell you what size the bolt will be. If you have the space use a 12 point socket on the bolt, if not it will need to be a ring spanner.
Post #77578 25th Aug 2011 6:51pm
RR8701
John thanks for the steps. I'll do some research and might even do a write up for it. Do you really have a garage I wasn't sure if mick was pulling my leg lol
Post #77584 25th Aug 2011 7:02pm
Yeah although its his own private one , but it is a Belter , if only i can find the picture of it Thumbs Up Thumbs Up Bow down Bow down
Post #77590 25th Aug 2011 7:05pm
A write up would be good.
Mick's always pulling something, and not usually someones leg Rolling with laughter Rolling with laughter
Post #77591 25th Aug 2011 7:07pm
Page 3 of 4 <1234>
