![]() | Home > Technical (L322) > folding wing mirrors |
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 ![]() ![]() ![]() |
could be the faulty microswitch problem, common fault. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35700 ![]() ![]() |
there is this in our wiki that might help
oodathort Member Since: 01 Nov 2010 Location: just there Posts: 191 ![]() |
some engineer |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6420 ![]() ![]() |
So the microswitch actually on the mirror housing somewhere? Where? or on the door switch panel? Photos will help? .
Mikeyjd Member Since: 14 Jun 2011 Location: Wrexham Posts: 543 ![]() ![]() ![]() |
What if the mirrors dont work at all. Mine have never folded in since I bought the car a few months ago. I have read a number of posts about sync problems etc. but nothing about the mirrors not working at all. Any ideas anyone? No longer FF owner but still interested. Present car Jaguar XE
First remove the mirror cover using a small but wide blade screwdriver to ping the cover off, then by the hinge part you will see a plastic cover over the micro switch the cover slides off towards you, the common problem is that the steel arm on the micro switch gets bent and does not make when in home postion if you re shape it and before putting cover back on try the operation, if its wrong the mirror will close in then return out imidiatley just play with the arm until you get it right |
Another pictorial howto on dismantling and accessing the microswitches for wing mirrors ('02 - '05) early type mirrors
done joe.. |
