Home > General > TD6 Battery
Page 2 of 3 <123>
johnson1
Rambles wrote:
will that battery fit into a full fat MY2011?
There shouldn't be any problems with your battery now. Have you had the AGM battery installed? If so, there is a deeper problem if you still have battery problems.
Post #78035 29th Aug 2011 7:19am
See also this thread regarding batteries:
http://www.fullfatrr.com/forum/topic2987-75.html .
Post #78036 29th Aug 2011 8:04am
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
I still have problems...and the AGM battery is only a few months old.
So I wanting to know if the Varta battery will fit?
Also...how do I put the bonnet into service mode so I can change the battery more easily?
Thanks
Post #78051 29th Aug 2011 11:49am
johnson1
Thanks
What problems do you have?
You need to do it via Land Rover as fiddling with the battery on an 11MY vehicle will give them a very easy way to void your warranty of any subsequent electrical issues, related or not.
Post #78052 29th Aug 2011 11:52am
Rambles
good tip re the warranty.....
I will suggest to them that they install the larger battery.
Post #78057 29th Aug 2011 12:28pm
S11X TT
2003 Range Rover Vogue Td6 Adriatic Blue
Rambles
Im fairly new to FFRR but I think the shell hasnt changed since the 2002 L322 - So it should do. It makes a hell of a difference. I didnt realise how crap the old one was until I fited the above. Its a tight squeeze and you need to open the bonnet fully - service mode, but its only half an hours work.
PS - If your car is that new Id be going back to LR -Isnt there a battery recall/upgrade for new ffrr
Regards
John Range Rover TD6 Vogue Adriatic Blue
Post #78058 29th Aug 2011 12:47pm
johnson1
...which they won't do because the AGM battery is already uprated and 'approved' by Land Rover UK for installation in 11MY Range Rovers only. I don't know the exact specs but i think you will struggle to get a bigger battery to fit in that space. Manufacturers are notoriously difficult at approving non-OEM items into their vehicles for multiple reasons. I think there is a deeper issue with your car as since the updates and new battery, it has all gone quite quiet. I've been using FBH, DVD player with engine off etc and haven't had one low-battery warning. What is yours doing?
Post #78059 29th Aug 2011 12:56pm
S11X TT
Is the battery you have fitted CCA(EN) - 920A?
Ive found I have no faults on cold start up anymore. The car seems more willing - which might just be in my head. Its been on a couple of weeks with no issue and Im not very careful. EG TV on not running, doors open / radio blasting when cleaning etc...
J Range Rover TD6 Vogue Adriatic Blue
Post #78060 29th Aug 2011 1:17pm
Rambles
FBH shuts down after 5-10 mins.
Radio shuts down when washing the car with door open and music on after about 20-30 minutes.
Post #78067 29th Aug 2011 2:17pm
johnson1
The radio etc is not a 'problem'. It's how the car has been programmed by LR at an attempt to eradicate battery drain problems. I believe the FBH time has been reduced to those parameters too. No way of changing it unfortunately.
In BMWs the ignition and radio etc switch off after 15 mins for the same reason. This is also true in my MY10 997 which is 10 odd minutes. All to save battery. Surely you can switch it back on after the 30 mins if you're confident in battery?
Post #78069 29th Aug 2011 3:19pm
Rambles
My dealer advises me that LR have released some new software again last week. I am hoping this now will cure the problem. Crossing fingers.....
Post #78200 30th Aug 2011 8:20am
Autobiography
2018 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
Word of caution. I'd check this isn't just going to further cause problems to you by reducing timings again. Has your dealer informed you what the update includes?
Post #78223 30th Aug 2011 10:01am
johnson1
+1
Post #78253 30th Aug 2011 12:20pm
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
Any opinions on this battery?
http://www.performancebatteries.co.uk/product/C31-1000/
130ah
1000cca
£99.95 delivered!
Post #79140 4th Sep 2011 1:40pm
the one i fitted and does the job very well is a bosch 020 with 110AH, 920CCA....so if that one gives you 130AH and 1000CCA then it does sound a good battery...just make sure the terminals are the correct way round....
Post #79144 4th Sep 2011 2:05pm
Page 2 of 3 <123>
