![]() | Home > Maintenance & Mods (L322) > coolant level low |
| pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865
coolant level low
| dan_uk_1984 Member Since: 12 Nov 2008 Location: Bude, Cornwall Posts: 4014
The thermostat is in no way related to the coolant level sensor, so not sure why you're being advised to replace that. Unless you have some other symptoms.
thanks dan where is the sensor you speak of located ...am i right in thinking its the one under the header tank? as this was my first thought then some one i know told me that he thought that was all part of the theromstat and as im not very familiar with these engines i thought he may be right despite me not being so sure ...im not getting any other symptons other than the ones i mentioned
ok just a quick update ive just checked my water and i have lost some but where to im not sure..??? "RANGEISM WILL NOT BE TOLERATED"
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35874
a member had the wrong rated coolant pressure cap fitted ,just wondering if yours has.... there's a thread somewhere on here about it... |
| Trist78 Member Since: 07 May 2011 Location: Worcester Posts: 78
Just Bought mine and had it had coolant level warning on it so topped it and it didnt go!! So I decided to change the coolant, put OAT in it. Also took the header out and gave it a clean. I found that it had some gunk in it and can only summise that the previous mix the coolant. I Also took the sensor out which is underneath the Header and only a twist and pull gave it a clean wasnt too bad though. The coolant hasnt come back since !!! Mind you I am keeping an eye on it just in case the header has a hairline crack!!! |
i have the right cap scarey i remember that thread thanks all the same
| Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470
The coolant tank sensor works on the SG of the fluid rather than a level. Mine pings up a lot as I'm nursing a water leak so top up with water so gradually the mix is getting weaker. I'm not sure how fast the coolant in the tank turns over so you might fill with water and get the bong as the density is wrong but actually the whole system is ok. You can buy a pipet type thing from Halfroads or eBay that measures the density using little coloured balls. Prob only a few £££.
thanks rob |
| SteveMFr Site Sponsor Member Since: 22 Nov 2009 Location: Strasbourg, France Posts: 1641 |
Aside from the sensor and header tank, the 2 other areas prone to leak on the V8's are the radiator (very small leaks often only noticeable as faint coolant odor because the coolant evaporates before it pools somewhere - the traces are visible with the radiator removed) or the heater hose under the intake manifold (usually leaves traces or even small drips at the rear of the valley). |
well fingers crossed i think it was just the lack of anti freeze ....i put some fresh anti freeze in today and the low coolent level light has stayed off.....i do think steve you may be right as im sure ive got a small leak on the radiator so will double check that when i get a chance lets just hope there not to expensive |
| J.Seven Member Since: 28 Aug 2011 Location: Estoril Posts: 29
Any update on this coolant leak? Thanks in advance. J.Seven |
i still loose a small amount of water but since making sure i had the right mix of anti freeze i no longer get the low coolent level light "RANGEISM WILL NOT BE TOLERATED"
Pret
