![]() | Home > Maintenance & Mods (L322) > coolant level low |
| Lee's Dad Member Since: 05 Jun 2011 Location: In with the POPE Posts: 54
Hover your mouse pointer over his little car below his avatar |
| Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470
Lee if you can tell me how that's done with an iPhone it would be much appreciated. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
| pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865
ive got a v8 4.4 petrol |
thanks lees for trying to help "RANGEISM WILL NOT BE TOLERATED"
Pret,
i dont have lpg but i did follow your thread and when i get time i will check those places you mention.......ive found a small leak from the bottom of my rad ....it appears to be an overflow pipe on the bottom left corner "RANGEISM WILL NOT BE TOLERATED"
Prob your rad. mine went and over time started to puddle under the car. Easy job to do and about £170 for a new one. Do you mean bottom left when your sat in the drivers seat? If it is think its from the alternator or the transmission stat. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
yes it is the bootom left from the drivers seat ...theres a little metal pipe that comes off the rad and that drips a little but not much and not all the time "RANGEISM WILL NOT BE TOLERATED"
| SGW Member Since: 09 Sep 2009 Location: Headcorn Kent UK Posts: 77
The pipe you are looking at is the radiator drain, make sure the screw is tight or may be the o ring needs replacing. |
+1 04, 4.4V8, Vogue Oslo Blue with LPG. "You can sleep in your car, BUT you can't race your house!!!!" If something can't be fixed with a hammer....... You have yourself an electrical fault! |
thanks guys.....love your avatar rob |
