Home > General > To service or not to service?
What should i do with my serviceing?
Main dealer service
18%
 18%  [5]
Indipendent service
44%
 44%  [12]
Service myself as per schedule
14%
 14%  [4]
Over service myself with more oil service and others on schedule
22%
 22%  [6]
Total Votes: 27
Page 2 of 3 <123>
supershuttle
Dirty hands - not for me Very Happy
But neither main dealer prices so I still need to find a good indy near Chorley (Lancashire) but will be March next year unless anything goes wrong in the meantime.
I will probably get them to change everything that's changeable, oil, filters etc do an MOT and see them once a year to repeat the process. Oh and I might pay extra to get that Censored armature towbar out of the reciever, I'm fed up of applying WD40 everytime its parked somewhere other than my drive (drips) and a bottle jack and big 'ammer to no avail every weekend. Geoff
Post #78284 30th Aug 2011 4:36pm
Supershuttle, if you don't use it i can take the whole lot off for you and put standard bits back on yours Very Happy
Post #78286 30th Aug 2011 4:44pm
supershuttle
Sorry mate, thanks for the offer, but I do use it. I would just like the two bits not to be seized together, because it's just wrong Banging Head - if they were dogs I'd be reaching for the bucket of cold water Smile Geoff
Post #78287 30th Aug 2011 4:49pm
AndrewT
New Zealand 2003 Range Rover Vogue 4.4 V8 Oslo Blue
Have you tried putting some heat on it? That usually frees up most seized bits.
Post #78288 30th Aug 2011 4:54pm
Why not put a big heavy unit on the back of it while suspension in access mode, then just lift up the jockey wheel a tiny bit, unlock the joint, then raise the suspension to normal heightand tap it with the hammer being careful to avoid backlash... should come out a treat as long as the nose weight isn't massively high but not far off the limit...
Post #78290 30th Aug 2011 5:44pm
supershuttle
The only heat I have available if the wife's hairdryer Laughing Geoff
Post #78294 30th Aug 2011 5:57pm
pretlove
christ you'll be there for ages Laughing "RANGEISM WILL NOT BE TOLERATED"
Post #78326 30th Aug 2011 7:57pm
Have you seen her hairdryer
Laughing Laughing
Post #78333 30th Aug 2011 8:18pm
I had to remove my towbar completely and take it to my MOT man where they used a oxy acetylene and a 200lb press to remove the armature
Post #78334 30th Aug 2011 8:18pm
supershuttle
How long had it been stuck in place - I reckon this one has been on for 4 years or more the bag and the rubber bung, fortunately still in the boot, look brand new. That's why I was going to ask the indy to remove it on the first service. Geoff
Post #78370 30th Aug 2011 9:49pm
My guess is that mine was fitted to the vehicle when new and never removed. The locking pin was seized solid and had to be removed in bits, then I spent months spraying loads of releasing fluids and forcing it with a jack at the back of the plate to no avail. The mechanic who did eventually part it could not believe it was such a stubborn item to split
Post #78371 30th Aug 2011 9:54pm
supershuttle
Cool,
I have tried the same things you have, only difference is that the locking pin comes out easily in fact I might as well leave it out as the other two bits are so stuck Confused Geoff
Post #78372 30th Aug 2011 9:57pm
Googsy
Is it possible to remove Towbar without the key as although I received one key I have lost it now I look like a farmer all year round. Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #78379 30th Aug 2011 10:11pm
AndrewT
If it's not as big as the one in Mick's picture then get down to B&Q and get one of those little plumbing blow lamps. They may look weedy but 5 minutes of heat with one of them and a hefty whack with a hammer and it should come out.
Post #78401 30th Aug 2011 10:53pm
I doubt if a plumbers gas torch from B&Q will work, there is not enough heat from it to sufficiently heat the surrounding metal.
The temperatures below are a rough indication of what each type of gas torch output is.
Butane..............1430°C = 2600°F
Propane.............1995°C = 3623°F
Mapp Gas..........3160°C = 5720°F (this is what I use)
Oxyacetylene.....3316°C = 6000°F
Post #78403 30th Aug 2011 11:12pm
Page 2 of 3 <123>
