Home > Technical (L322) > How do I enable "lazy locking" please?
RRV
United Kingdom 2015 Range Rover Vogue TDV6 Santorini Black
On my 2003 TD6 Vogue,I had the lazy locking feature pre enabled(opens/closes windows/sunroof remotely).
On my new 2007 SC Vogue SE it is not enabled,the book says LR techinicians can do it....but does anyone know please how to perform such a simple task? If you have nothing nice to say,say nothing at all.
Post #7796 16th Oct 2009 6:55pm
Think you still need a dealer to do it via the OBD Discovery 4 HSE
Post #7799 16th Oct 2009 9:00pm
VMPP
Portugal 2007 Range Rover Vogue TDV8 Buckingham Blue
Yes, on 2007MY to 2009 MY, all those settings must be made by the dealer.
There are a bunch of settings you can chose from....
On the other forum, there's a post with the available options, search it.
Post #7815 17th Oct 2009 7:16pm
nbunney
United Kingdom 2018 Range Rover Autobiography SDV8 Corris Grey
Other forum?
This is the one and only. Bow down
Post #7819 17th Oct 2009 8:54pm
jayzee
2006 Range Rover Vogue SE Supercharged Java Black
Definitely through the OBD - are you sure?
In that case, it doesn't have to be a main dealer then?
Post #7820 18th Oct 2009 9:48am
RRV
Does anyone have any idea?I must be able to do a setting of some sort?
Thanks for the replies. If you have nothing nice to say,say nothing at all.
Post #7822 18th Oct 2009 11:37am
VMPP
nopes.......You're pretty stuck.
All you can change is what you see, clock, reset odometer, central screen menus, etc...
All those other things, lazy locking, single point entry, autodoor locks on the move, PDC sound level, headlamp timer, low outside temperature warning, key/seat memory activation, etc... must be set by the dealer or someone with the software to ''read'' the car.
Post #7829 19th Oct 2009 12:50am
RRVSE
United Kingdom 2013 Range Rover Vogue SDV8 Corris Grey
You can however do the headlamp timer yourself (by following the info on another thread on this forum). I did it on mine , so now, if I want the lights on long enough for me to get in the house, I simply flash the lights and the 'main beam delay' message now appears on my dash display (previously, they just flashed and went straight out as usual) and the lights stay on for a pre-defined time period. Very Happy Steve
Main car : FFRR L405 Vogue SDV8
Other car : Vauxhall Lotus Carlton
Past cars : FFRR L322 Vogue TD6 SE (Sept 2006 MY07) ; LandCruiser SWB ; 4-Runner ; Supras; XJS V12 LeMans
Post #7843 19th Oct 2009 5:49pm
