Home > General > Fitting towball
Fitting towball
I might be missing something here but how do you fit the towball into the receiver?
I have lubricated all the bits and everything is free but I can't get the towball to fully engage with the receiver(?). I turn the spring loaded handle fully and the 3 ball bearings partially retract but not fully, consequently the towball wont fully engage. Am I missing something obvious?
Also what is the purpose of the cam type lever on the front of the towball?
I assume if I ever get the two bits to engage the idea is to lock the handle and remove the key? My key is only removeable in one position, is that correct?
Anybody happen to have a set of instructions?
Having a grey moment Sad Smile
Post #78635 1st Sep 2011 12:29pm
nbunney
United Kingdom 2018 Range Rover Autobiography SDV8 Corris Grey
Are you trying with the key in or out?
Post #78639 1st Sep 2011 12:43pm
With the key in or out the result is the same.
Also the key doesn't seem to lock anything or could it be the towball has to be engaged before this happens?
Post #78643 1st Sep 2011 12:56pm
ric355
The wheel has to be 'cocked' before it will engage. Turn it round until it locks in place, then push into the receiver. I can't remember if you have to pull it out at the same time as turning it but no doubt someone else will remember.
Post #78645 1st Sep 2011 1:03pm
Give the man a coconut Very Happy
Now all working correctly, I can take my trailer load of rubbish to the tip now.
Thanks for your help Thumbs Up
Post #78648 1st Sep 2011 1:16pm
not one of landrovers best ideas ,but it does work...
Post #78689 1st Sep 2011 4:25pm
