![]() | Home > Maintenance & Mods (L322) > Trim removal |
Anybody have experience of removing the trim that surrounds the drivers window/mirror/access switches as I am fitting a replacement that I know pushes on but I want to know which end to pull up first to remove old? |
Just tried does not seem to want to pull off.... |
Is it the switches panel? |
Yes!
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6374 ![]() ![]() ![]() |
I take it you have removed the door card? You access them all from behind I think Discovery 4 HSE
I think from memory the door car has to be removed to allow the switch panel to come off |
OK guys I thought it popped off but looking at the new trim I think its screwed in from behind the door card |
Nothing in WIKI or search on Door Card Removal ?.
Now that I am expert at - will try and get back |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35780 ![]() ![]() |
any help? |
Perfect Stan but I WILL lose that first bolt |
Again from memory remove the two screws at the end of the pocket and the screw from the interior door handle. Using a large flay bladed screwdriver gently prize the bottom of the door card away from the door, it is held on with plastic poppers, once you have a couple of the poppers prized from the door use your hand to pull the card away. Once all poppers are loose lift the door card upwards to release it from the top |
get mini gaz to help you gary... |
Oops forgot the 10mm bolt |
