Home > Technical (L322) > Another keyfob/alarm issue
daveym
United Arab Emirates
Ive searched and searched this and other forums but i can't find the answer.
My symptoms were that my keyfob wouldn't lock/unlock doors, therefore following the guidelines on here i resync'd all was well for about 5 minutes when the keyfob wouldn't unlock/lock again. Strange!
I've tried holding the lock button and locking the doors procedure but that hasn't worked either. When i did try and resync my keyfob at the end of initialising, the keyfob continued to flash for a further 15secs which it hasn't done before and the doors did not lock unlock as they usually would when resyncing. anyone any ideas - similar problems to mine?
Cheers
Post #77728 26th Aug 2011 5:57pm
possibly the battery on the keyfob or range..
Post #77730 26th Aug 2011 6:02pm
daveym
The battery was replaced a couple of weeks ago. I tried again today and all worked well for about hour when it seemed as if the remote "forgot" who's car it was unlocking. I resynced it all again and the same thing keeps happening - its very frustrating! Any ideas anyone?
Post #78776 1st Sep 2011 9:59pm
daveo
the cheapest option would be to get a second hand key and re-sync to see if its the key or module..
have you tried disconnecting the car batt for a while.. V8 facelift Range Rover Autobiography 22" wheels.
Post #78779 1st Sep 2011 10:33pm
Fr_Raf
France 2004 Range Rover Vogue 4.4 V8 Java Black
Are you sure the new battery is realy good ?
May the cheapest option should be replacing again the battery ?
Post #78781 1st Sep 2011 11:33pm
daveym
Do you mean the car or keyfob battery?
Post #78787 2nd Sep 2011 8:38am
i think he means the key fob battery..... does the other key work ok , if so it could be you have one dodgy key fob ..
Post #78794 2nd Sep 2011 8:58am
