Home > General > What kind of roof rack?
starman
Sweden 2005 Range Rover Vogue 4.4 V8 Giverny Green
My third post here Smile
Hi all, i just got my self a 05 Vogue.
We travel a lot to the northen part of Sweden for skiing and therefor need to attach a roofbox ontop of the RR.
My car doesn´t have the roofrails. What options do i have?
To be hornest, i don´t like those crossbars that you see on some cars that sort of stick out wider than the car itself.
Is it possible to attach crossbars in those three "holes" that are on each side of the roof?
Or do i need to get the roof rails first and then attach the bars on to them?
thanks
Peter
Post #79082 3rd Sep 2011 11:33pm
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
Hi mate
I bought this kit.
I think he ships overseas.
Cheers
http://www.ebay.co.uk/itm/RANGE-ROVER-L322..._873wt_689
Post #79083 3rd Sep 2011 11:42pm
Do those ones need to have the rails permanently fitted or are they removable ?
Post #79158 4th Sep 2011 3:51pm
PaulB
You fit the rails to the roof and leave them on.
Then I will fit the bars when required.
Post #79181 4th Sep 2011 5:53pm
I think it worth noting that the rails are quite "tall" and change the floating roof profile somewhat. I would only fit them if I was going to use the cross-bars on a regular basis. Neutral
Post #79183 4th Sep 2011 6:01pm
Tim in Scotland
Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland
2010 Range Rover Vogue TDV8 Stornoway Grey
You don't need to fit the lengthwise rails - there are "Sport" bars that also locate directly into the same fittings in the roof and the cross bars you have look just like them. 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #79189 4th Sep 2011 6:43pm
Sounds interesting but to use the roof fitments you have to remove the flush factory rails so if crossbars where fitted you would surely have two exposed grooves where the rails should be? Confused
Post #79190 4th Sep 2011 6:48pm
simon1233
Would something like this be suitable?
http://www.roofbox.co.uk/scripts/rbvehsel4...odid=21534
I think these would locate into the existing fittings under the moving flaps on the roof (3 of on each side of the roof) and also give you the look you want.
If you search the manufacturers website they may have an importer already in Sweden Thumbs Up
Simon
Post #79194 4th Sep 2011 7:21pm
Simon
Nice looking kit that I would say this a very good option Thumbs Up
Post #79202 4th Sep 2011 7:50pm
Whats wrong with getting a trailer and pulling the kit behind you, even in bad weather it would be better traction wise than having more wieght up top making the car more unstable??
You can then put what you want on or in the trailer and not have to worry about trying to reach up top of your FFRR unless your about 6'5"> then this is something you should consider, just think how much of a PITA it is cleaning the roof properly every week and you get my drift Smile
Post #79234 4th Sep 2011 10:05pm
starman
Thanks all for inputs.
Ok so it looks like there are solutions for me. That there are bars that attach to the roof without needing the rails.
But on the other hand - if one should use two of the mounting places in the roof, would mean that the box will either be mounted on the bars to much to the rear or to much to the front, depending on which "holes" are beeing used.
The best is to attach a box central on to the cross bars, which wouldn´t be the case here.
Kingpleb, A trailer is not perfect for us.
You are right, to be able to reach the box one needs to be atleast 6´5.
I´m 6´6 Smile
Post #79273 5th Sep 2011 9:30am
I have the roof rails fitted so as not to scratch my roof when the garage door blows down in bad weather when im reversing my car in!!! Works a treat! Thumbs Up
Post #79278 5th Sep 2011 9:38am
igore
England 2002 Range Rover Vogue Td6 Adriatic Blue
i thought that the vogue had a ski bag inside where the center arm rest on the back seats are. sorted Thumbs Up ONE LIFE LIVE IT
Post #79299 5th Sep 2011 11:23am
starman
It does igore,
But this particular Vogue also includes a wife that packs loads and loads of things Very Happy
So simply no space to have four pair of skis in the car.
Post #79311 5th Sep 2011 1:42pm
nbunney
United Kingdom 2018 Range Rover Autobiography SDV8 Corris Grey
Starman, can you get Thule roof racks over there? If so have a look at their version for the ffrr, mine was fine.
Post #79324 5th Sep 2011 4:03pm
