Home > Technical (L322) > After market reverse camera
andyboy
Wales 2004 Range Rover Vogue Td6 Java Black
i bought a reverse camera for my 2004 td6 from flea bay and was wondering if i need to get anything else for it to work? (its the one that fits in the light on the number plate.) Smile
Post #79360 5th Sep 2011 6:14pm
pretlove
have you got a link for that as id like one for the number plate light area also did you check yet to see if it fits "RANGEISM WILL NOT BE TOLERATED"
Post #79372 5th Sep 2011 7:41pm
andyboy
http://www.ebay.co.uk/itm/Reverse-Camera-L...8728wt_902
http://www.ebay.co.uk/itm/CCD-CAR-REVERSE-...7022wt_975
theres two i got he second one its for a bmw x5 but they are the same. ihavn't had it done yet but it looks like it will fit. iwill let yo know when i get it done.
Post #79393 5th Sep 2011 8:16pm
Thought they were for the Sport as the FF'S are at the top of the tailgate …..
Post #79400 5th Sep 2011 8:48pm
finlander
England 2003 Range Rover Vogue 4.4 V8 Buckingham Blue
can you let me know how you got on and if it all works as I am thinking of adding this to mine
cheers
Geoff Smile
Post #93444 20th Nov 2011 8:51pm
daveo
hi, i would like to know if you get it to fit as it looks similar to the one i bought a while ago, it was from a different seller.
any way as i said check the fitment before you buy your other stuff.
you will need an AV loom like this one
http://www.ebay.co.uk/itm/BMW-Range-Rover-...2eb93766b2
you will also need a relay that when the reverse is selected the 12v live switches and allows an earth to connect to pin 17 on the tuner as well as power to the camera,this will switch your monitor over to AV and display the image, ntsc only V8 facelift Range Rover Autobiography 22" wheels.
Post #93448 20th Nov 2011 9:22pm
daveo
did you order NTSC..
as listing states
TV System: NTSC default & PAL request V8 facelift Range Rover Autobiography 22" wheels.
Post #93450 20th Nov 2011 9:24pm
33CHINACARS
Australia 2017 Range Rover Autobiography SDV8 Santorini Black
I'm interested too, Have a MY05 TD6 HSE with touch screen radio. No TV, Phone or SAT-NAV. Will it work without TV.
Gary
Post #93564 21st Nov 2011 4:14pm
daveo
when you say it has no tv but you have a touch screen fitted, was that a retro fit... V8 facelift Range Rover Autobiography 22" wheels.
Post #93566 21st Nov 2011 4:21pm
33CHINACARS
Only had RR a few months . But believe touch screen is original
Gary
Post #93572 21st Nov 2011 4:35pm
Gary
on the back of the touch screen there are 3 inputs...you can connect a camera to one and get the it activated by accessing the CCF via a faultmate or similar..
edit...rear of screen..
Post #93576 21st Nov 2011 4:38pm
daveo
gary, so in your boot do you not have the tv module. beside that the touch screen still has the av in port so yes you could put the rev cam on V8 facelift Range Rover Autobiography 22" wheels.
Post #93577 21st Nov 2011 4:39pm
33CHINACARS
Big thanks to Stan & Daveo.
NO TV module. No Sat - Nav DVD. No Phone module ?? but phone cradle in centre consule
Touch screen says " Phone not fitted " " Navigation not fitted ".
Is there anything else other than Camera, Leed & activation that I need to make it all work.
Stan do you have pic of front off unit to make sure I have same unit
Thanks Gary
Post #93672 22nd Nov 2011 7:37am
supershuttle
I don't want to hijack the thread, in fact you can have it back in a minute, but it seems that there is a lot of rear camera expertise here that might be able to answer a simple question. I have a 2007MY FF and of course that has a reverse cam at the top of the tailgate - it works - BUT the quality isn't that great and I think that may be normal.
So the question is can the camera part itself be swapped to improve the video?
Thanks and apologies once again for the hi-jack Very Happy Geoff
Post #93679 22nd Nov 2011 9:14am
geoff,
http://www.fullfatrr.com/forum/topic6576.h...rse+camera
but i dont think mick went through with replacing his..
Post #93683 22nd Nov 2011 9:33am
