![]() | Home > Maintenance & Mods (L322) > 2010 CONVERSION HELP |
WHIZZ73 Member Since: 31 Jan 2011 Location: Hemel Hempstead Posts: 55 ![]() ![]() ![]() |
The LED's are possibly the Daylight Running Lights and would need to have an ignition live circuit to them so they are on all the time, IIRC they then shut off when normal lights kick in but i could be wrong.
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1055 ![]() ![]() |
I haven't, but I'd recommend more time on google, and less time in the rain! Try this link for a start: http://www.rangerovers.net/forum/viewtopic.php?f=2&t=39543 If that doesn't help you I'm sure somebody will be along who's done the conversion. Good luck! 2012 SDV8 Vogue SE |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35741 ![]() ![]() |
http://www.fullfatrr.com/forum/topic4066.h...conversion
Thanks for the links but these do not hold any answers |
re the front, some older ranges had bi-xenon headlights which meant a piece of metal would clear the bulb when in high beam and come down for dip, the main halogens are for flashing and no use as mains as only 10 volts in fed to them... ....
craig , i've deleted your mobile number as you dont want every tom dick and harry to be ringing you..best to pm whizz73 with the number.....
do a search on the MKIII forum at rangerovers.net . there were a couple of diagrams floating around there. |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6808 ![]() ![]() ![]() |
I had links for l322.com, where this conversion was well documented, but it seems to have gone to the great website in the sky........... Got - 2017 SDV8 Autobiography in Loire Blue
