![]() | Home > Maintenance & Mods (L322) > egr blanking kit for td6 |
arron Member Since: 22 Sep 2010 Location: lincolnshire Posts: 123 ![]() ![]() ![]() |
too late, i fitted one to mine over a year ago. ner ner |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35828 ![]() ![]() |
but you live in lincolnshire so you dont count , sorry.... |
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 ![]() ![]() ![]() |
Just arrived in the post! |
i think it does..seen various pictures of the kits and some had gaskets...might be able to use the old one.. |
@arron , have you any tips re fitting this .. |
No gasket required as a rubber sealing ring does the job of sealing between EGR housing and inlet manifold.
whats it drive like now rich.... |
GregP Member Since: 11 Dec 2010 Location: Exmouth Posts: 1084 ![]() ![]() ![]() |
Anything less than 50mpg and I'm asking for my money back ![]() Plus I expect to be able to smoke a supercharged!! ![]() Adriatic Blue with Parchment leather. |
Scarey... Unable to tell because the gearbox has decided to die! ![]() |
that's bad news rich, hope you sort it out.. |
PJS Member Since: 06 Jul 2010 Location: Yorkshire Posts: 506 ![]() ![]() ![]() |
Once its sorted update us on the mpg change |
Ouch on the gearbox. Hope you get it sorted ASAP and with minimal cost. FFRR TD6 HSE
mine arrived today and was dually fitted ..the lower bolts were a bit fiddly but other than that it went pretty smoothly...i re-routed the vacuum pipe and forgot to block it so a bit of head scratching wondering what the hissing noise was when i ran the engine..
