![]() | Home > Technical (L322) > Sunroof Initialisation Procedure |
Since disconnecting my battery my sunroof has been playing silly beggars and not finding its closed position fully.
Smells like WIKI spirit |
Crack on! ![]() |
Did this go in the WIKI?
OK result is neither worked for me. |
Out to try!
According to manual the reset procedure is:
DavidP Member Since: 20 Oct 2010 Location: BN Posts: 425 ![]() ![]() ![]() |
I had the 'bounce back' problem after re-setting the roof. With the sunroof open I pushed and held the 'tilt' bottom for +20secs [until after the 2nd thud of the motor] and it seems to have cured it.
simon1233 Member Since: 13 Jun 2011 Location: Leyland, sometimes Darmstadt Posts: 650 ![]() ![]() |
After my recent 'lack of electricity issue' (new alternator fitted |
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 ![]() ![]() ![]() |
I don't think it does close from tilt with just a single push. Mines doesn't anyway - and neither did any of my P38's sunroofs. |
Hi Simes
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2068 ![]() ![]() ![]() |
Have you Re-set and or re-calibatrated it yet ?
Thanks Nigel |
Finally the car has accepted that I would not give up and on what feels like the 100th time of doing exactly the same procedure It finally works!
