![]() | Home > Technical (L322) > obd leads |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6381 ![]() ![]() |
Is it not a better idea to fix the problem rather than clearing the error messages? Discovery 4 HSE
OBDII is different to the EAS stuff (although it's all accessed over the same port)
shaun10569 Member Since: 20 Oct 2009 Location: lancashire Posts: 13 ![]() ![]() ![]() |
this is why i need to obtain some software and lead so that the cause can be found and rectified, as i believe when the problem is fixed the error message will be removed itself as the car checks the systems quite often, hence asking for advice re where ro get the lead and software. thanks |
When you took it to the garage to get the fault cleared, did they tell you what the fault was? |
no just said .it should be ok now any probs fetch it back ......so i did and he said cant do it for a couple of weeks. hence the frustration |
