Home > Technical (L322) > wheel
tolley
wheel
just look at a ffrr few bit not sure about the steering wheel would not adjust up or down ,sould the hight ride adjust when park't.
it was a 04 vogue 76th £13600
Post #80221 10th Sep 2011 11:09am
when you start the range the steering wheel should go to a pre-set position, when you switch of the engine the steering wheel should re-tract and go up ..
the steering wheel can also be adjusted via a lever just under the indicator stem..
Post #80223 10th Sep 2011 11:36am
tolley
steer
thanks scarey
came out when started but i had no movement up or down just in and out.
the other was the ride hight adjuster just in front of the gear knob ,i had no adjustment when it was park't and the engine was running?
Post #80240 10th Sep 2011 1:34pm
JustinP
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
Losing the steering wheel up and down movement is quite common, try using the search facility on this forum to find out what's involved in repairing it.
The air suspension height can be operated when stationary, best to stick it in neutral to ensure you don't stress the suspension components too much, better still operate it when moving slowly, i.e. select access height when slowing just before you park and it will raise automatically when you pull away.
Gone - Range Rover Supercharged 2006
Post #80243 10th Sep 2011 1:40pm
tolley
not working
yes it might be costly to fix,tryed the height when stationary but no joy so that might need fixing.
Post #80260 10th Sep 2011 2:43pm
GregP
United Kingdom 2002 Range Rover HSE Td6 Adriatic Blue
Mine had the same problem but I got it fixed under warranty. Garage said it cost em 900quid for the part they needed to fix it FFRR TD6 HSE
Adriatic Blue with Parchment leather.
Post #80266 10th Sep 2011 5:09pm
tolley
STEER
I THINK I MIGHT GIVE THIS ONE A MISS
Post #80269 10th Sep 2011 5:20pm
GregP
Or if the car is being sold by a garage either get them to fix it or ask for money off so you can fix it. FFRR TD6 HSE
Post #80277 10th Sep 2011 5:40pm
bozmandb9
2013 Range Rover Vogue SE TDV8 Causeway Grey
Re: STEER
Sounds way over priced for an 04 anyway, I'd either go for a facelift for maybe a little more money, or look at 02 onwards, probably one or two good ones advertised on here! 2012 SDV8 Vogue SE
Post #80279 10th Sep 2011 5:41pm
tolley
PRICE
Do you think so i thought it was not to bad.
how much are facelift.
Post #80289 10th Sep 2011 6:03pm
tolley
spec
just found another 04 69th 13800 vogue FSH landrover.
what do you think
Post #80290 10th Sep 2011 6:06pm
Well as a guide I paid £12900 for my 05 pre-facelift td6 vogue with 125k on the clock, and full lrsh. Fair enough the boot smelled of dog, still does a little until I steam clean it, and the lower tailgate wiring and solenoids were shot but it just takes good hunting down, specially as I don'tind doing a bit of work to get it A1 again Smile
Post #80328 10th Sep 2011 9:28pm
GregP
Lower miles will mean a higher price FFRR TD6 HSE
Post #80336 10th Sep 2011 10:10pm
