![]() | Home > Maintenance & Mods (L322) > 2010 brembo brake calipers will they fit ? |
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 ![]() ![]() ![]() |
hi all does anybody know if the 2010 brembo 6 piston calipers and 380mm discs as fitted to the s/c fit a 2005 with 19'' ?
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35859 ![]() ![]() |
there are 2 size discs and the 380mm ones i believe are the bigger ones and like alan says ,they need 20'' rims.. |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2626 ![]() ![]() |
All 2011-on cars have the same 380mm/6-piston Brembos (in the UK at least), and they obviously fit behind the standard 19" Style 15 wheels, but not some (all?) of the earlier 19" designs. |
simon1233 Member Since: 13 Jun 2011 Location: Leyland, sometimes Darmstadt Posts: 650 ![]() ![]() |
My 2007 TDV8 Vogue has Brembo's and they do fit with a 19 inch wheel |
They're not the same Brembos. |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6837 ![]() ![]() ![]() |
I'm sure I read somewhere that the wheel offsets on newer wheels were changed to accomodate Brembos? Or as maybe as Stan says, these are the smaller Brembos? Got - 2017 SDV8 Autobiography in Loire Blue
i think there are 344mm ,360mm and 380mm diameter brembo discs...i'm sure dan [duckworths] will confirm.. |
The 4-piston Brembo calipers are half the size of the 6-piston ones, and use a smaller-diameter disc. |
