Home > Technical (L322) > td6 air con condenser
has anyone fitted or knows how to fit one of these.. ... - .- -.
Post #82318 19th Sep 2011 10:16am
Pauld
United Kingdom 2004 Range Rover Vogue Td6 Zermatt Silver
No,
but if you are dealing with refrigerants it will need to be done by a specialist.
Would suggest talking to a refrigeration service company, as they could de gas the system and re gas it when you have replaced.
Post #82325 19th Sep 2011 10:23am
the system is empty, hence the condenser replacement..appreciate the advice.. ... - .- -.
Post #82327 19th Sep 2011 10:25am
Cant see it being to hard a job. If it's the one to sit infront of the rad you might have to remove it to gain access but shouldn't be to hard. Have you looked in Rave to see what's involved? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #82342 19th Sep 2011 11:58am
it is in front of the radiator rob,that's why its got holes in it .probably damaged from stones and debris from the road.. ... i havnt browsed rave yet but will do.. Thumbs Up ... - .- -.
Post #82348 19th Sep 2011 12:11pm
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
When I replaced mine, I removed the slam panel and front grill. Saves undoing the viscous fan unit.
Then condensor slides upwards and out of car.
Post #82355 19th Sep 2011 12:21pm
not sure what the slam panel is rich Embarassed .. ... - .- -.
Post #82356 19th Sep 2011 12:31pm
Richcl
Above your headlights, below your open bonnet, the bonnet "slams" on it Smile
I did post a pic, but I'm sure I posted it in the "What have I done in my FF today" thread, so buried...
Post #82357 19th Sep 2011 12:34pm
thanks Wink ...so a fairly quick job then.. ... - .- -.
Post #82358 19th Sep 2011 12:35pm
Richcl
Not to bad, an hour (ish) Some fittings to remove, i.e. bonnet cable and air duct.
One of those procedures that you get away with by not following RAVE.
Post #82359 19th Sep 2011 12:37pm
much appreciated rich... ... - .- -.
Post #82360 19th Sep 2011 12:42pm
SteveMFr
Site Sponsor
2nd Rich's advice.
4 end bolts, 6 middle support bolts and the slam panel comes off (no need to disconnect the bonnet release cable - just lay the slam panel on the motor. But if you do want to release the cable, there is a connector on the drivers side), 2 plastic caps over the ends of the condenser - that's it IIRC (oh and obviously the AC lines).
All BMW era condensers are the same too - petrol and diesel, so you can go shopping. I'm not sure about the Jag engined RR's. Do Not buy at the stealer's, though! Shocked
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #82410 19th Sep 2011 3:12pm
thanks steve, condenser ordered @ £168 delivered with 18 month warranty... ... - .- -.
Post #82414 19th Sep 2011 3:21pm
SteveMFr
Site Sponsor
That seems quite reasonable.
I got lucky and ebayed a new condenser for $115 - in the US. Unfortunately shipping would've killed any savings so I waited till my next trip to the States and brought it back in my luggage. I had to do a special packaging job, though. If I would've charged myself my regular hourly rate for all that - I could've gone directly to the stealer,,, Rolling Eyes
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #82435 19th Sep 2011 4:33pm
$115 converted to uk would be even cheaper...dont think the wife would allow me to get a flight to the states to collect one... Laughing
btw , what did you do with the old one?. ... - .- -.
Post #82438 19th Sep 2011 4:37pm
