![]() | Home > My Range Rover > Identify my car! |
| Cappo Member Since: 19 Sep 2011 Location: Kent Posts: 537
Hi all, new to this site. Have owned a Series III and a P38 in the past and just taken the plunge into L322 ownership with a nice 2006 Java Black Vogue 4.4.
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35872
re the towbar, it sounds like you have the standard landrover fitted towbar..if you havnt got the 'bit' that fits into the square hole then they are available on ebay ,either in the swan two piece type or the fixed bar with a flange on it..
| allycraven Member Since: 28 Mar 2011 Location: North Craigo, Angus Posts: 440
Mine's an '07 4.4 V8 and its Java black...
| bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1055
It sounds very likely to be a facelift, if you post a photo of the engine we'll be able to tell you straight off. On the facelift the headlights were not quite rectangular, on the inside there's a semi circular incursion into the grill.
| nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2075
I have a flange towball for sale |
| kingpleb Member Since: 07 Jun 2011 Location: Maybe here. Maybe there, I get everywhere! Posts: 8455
I would like a picture of your under carriage as that sounds very familiar to the standard setup that I just took off mine.
Kingpleb - not the former Fiat Coupe owner, surely??? |
That would be the Armature! I think you can probably get the whole lot for around £350. 2012 SDV8 Vogue SE |
PMPL yes cappo of the same origin no doubt We both have moved on and up a smidge aint we, or you still got yours as well |
I understand the pictures a little better now From what i saw on other posts of these forsale, was that the crossemember section was part of the whole lot and not available as a stand alone. If it is then i may have to take my back bumper off and get myself one, would look a wee bit tidier but i've got mine looking good at the minute and need to get some new piccies up of her, probably do is this week when im rested from a night shift and not counting |
http://www.fullfatrr.com/forum/topic7117.html
| JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889
The following thread contains some excellent photos of the main westfalia tow bar components.
Ha ha, small world and all that! I still have mine, in fact I just collected it back from Rog after some work this evening. Had a Monaro, a P38, a Ford ranger and one or two others in between, but the FFRR is new (to me) this weekend. I'll PM you the whole tale when I get a moment - do you know/remember CarlT? |
Thanks Justin. I was hoping that the crossmember would bolt up to the brackets already on the car, which would have made things easier. My alternative is a Tow Trust towbar which has a detachable flange hitch (included) for a shade over £200, so if I've got to remove the bumper anyway I may just go for that one. |
