![]() | Home > Maintenance & Mods (L322) > Stuck alloy |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35834 ![]() ![]() |
a real good go with a rubber mallet, which you have probably done already or place a large piece of wood on the inside rim and hit the wood with a proper lump hammer...make sure you have a couple of nuts screwed on a little bit otherwise when the wheel comes it'll get damaged.. ... - .- -.
A fairly common problem. I used a length of 3x3 wood against the inside of the offending rim, end on. Hit the other end with a lump hammer. Took 2 blows for mine to come off whereas the rubber mallet was a complete waste of time.
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3983 ![]() ![]() ![]() |
Bigger hammer and a lump of wood usually works eventually. |
A few hard kicks on the outside of the tyre wall usually works |
ric355 Member Since: 02 May 2011 Location: Surrey, UK Posts: 302 ![]() |
Thanks chaps - will try end on piece of wood and lump hammer tomorrow ! |
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 ![]() ![]() |
Try loosening all wheel nuts by only two or three turns, then jack the other side of the car as if removing the opposite wheel (placing more vehicle weight on the offending wheel). Making sure the vehicle is safe and supported (jacked correctly) then hit the offending wheel with your mallet... I had to do it on the side of the road one night way back when and it worked in an "emergency puncture" scenario...
