![]() | Home > General > R A N G E R O V E R - rear lettering |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3984 ![]() ![]() ![]() |
Run masking tape top and bottom of the existing lettering (or somone elses) and mark out the lettering edges and then either clean up and apply new lettering or remove tape, clean up and reapply marked up tape.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35838 ![]() ![]() |
+1 ... - .- -.
Just replaced mine after the dreaded rust not rust according to LR and had to have my upper tailgate re-sprayed and mine came on a strip pre spaced just apply centrally and level |
While your at it you should consider the brighter silver lettering as on the 2010 model I plan to change mine as I have some chips in my upper boot lid that I will get resprayed at some point and will also replace bonnet ones also. Present :2008 TDV8 HSE
liverpoolphil Member Since: 28 Jan 2010 Location: Lancashire Posts: 111 ![]() ![]() ![]() |
This is a good shout, just need to find someone with an ffrr, who will let me use there tail gate for a short while. If anyone's bored at the weekend and fancies making me a template, I'll happily pay or make a donation to the forum ![]() |
PM me your address and I'll put you something in the post.
carlos50 Member Since: 03 Feb 2011 Location: North England Posts: 717 ![]() ![]() ![]() |
I was going to do the 2010 letters but its £75 for the front and rear, cant do just one and that cost is hard to swallow when my original letters are fine |
andyboy Member Since: 24 Aug 2010 Location: south wales Posts: 540 ![]() ![]() ![]() |
i have got the front and rear templates in the garage somewhere. I'll dig them out if you don't get any luck. |
just want to say a big thanks to david (nicedayforit) for sending a very detailed template to help attach my letters, made a donation to the site |
a big |
