Home > General > Check Coolant Level :-(
JustinP
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
Whilst driving to the dentist, the chap behind flashed, pulled along side and warned me that my car was dropping a considerable amount of water, just as he finished telling me, my car bonged to warn me to check the coolant level.
I'm now waiting to be recovered Sad
Gone - Range Rover Supercharged 2006
Post #83184 22nd Sep 2011 4:13pm
anything obvious justin? ... - .- -.
Post #83187 22nd Sep 2011 4:17pm
Reformed
Hopefully nothing to much to fix. Reformed
Post #83189 22nd Sep 2011 4:17pm
mzplcg
Ah you supercharged loadsa munny owners can afford it Wink
Hope it's nowt serious Justin. Thumbs Up
Dom.
Post #83192 22nd Sep 2011 4:22pm
JustinP
I can't see anything obvious.
Post #83195 22nd Sep 2011 4:27pm
JustinP
Dom.
Dom - My kids can only afford to eat every other day because I bought a FFRR SC
Post #83199 22nd Sep 2011 4:36pm
M44K TS
Mine did the same after a 400 mile drive to Aylesbury, pulled up outside the hotel when I got the warning, mine was a small split in the header tank to radiator hose, not a very big job, lets hope yours is just as minor. 2006 Mercedes CLS
1991 Retro-style Mini
But really finding it hard to fight the urge for a S/C...
Post #83255 22nd Sep 2011 6:02pm
JustinP
The LR assist chap located the offending coolant pipe, and as the split was close to the edge he chopped about 20 mm off the end and reattached with a new jubilee clip. So I'm mobile again Very Happy
Obviously this is only a temporary fix, so I will get it booked in for a replacement, as long as its covered by the LR warranty.
The split hose is at the front of the engine in the V between the cylinder heads Big Cry The LR mechanic removed the thermostat housing to get to it, along with the multitude of pipes and electrical connectors that attach to the thermostat housing. The other end of the pipe heads further into the centre of the engine and disappears, so I've not idea what its connected to at the other end.
Having watched the thermostat be removed I would feel confident doing the job myself if I new where the other end went, from what we could see it looks like the supercharger will need to be removed to get to it.
Fair play to the LR assist chap who spent over 2.5 hours on my car Bow down
Post #83326 22nd Sep 2011 8:37pm
pretlove
glad it was nothing serious Thumbs Up "RANGEISM WILL NOT BE TOLERATED"
Post #83327 22nd Sep 2011 8:40pm
magic mate.. Thumbs Up ... - .- -.
Post #83328 22nd Sep 2011 8:42pm
letsavit2
United Kingdom 2004 Range Rover Vogue Td6 Java Black
good.... Thumbs Up 2004 black Vogue TD6
Post #83332 22nd Sep 2011 8:52pm
CG-SC
2006 Range Rover Autobiography Supercharged Zambezi Silver
Just checked my prinouts from Topix - there are only two hoses that run between the cylinder heads - these are the heater feed and return pipes, one pipe connects onto a connection on the thermostat housing and the other goes onto a connection on the block.
I reckon that these hoses will come as a full assembly (from memory, both of them have a combination of rubber and metal sections - these are the pipes that my LPG vapouriser is connected into.
You may be lucky and not have to remove the Supercharger, chargecoolers etc Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather.....
Post #83341 22nd Sep 2011 9:11pm
JustinP
Looking at microcat it look like the pipe runs from the font of the engine to the back, it's the narrower 25mm pipe not the fat stumpy one that connects to the engine block.
If the supercharger needs to be removed, my fingers are well and truly crossed in the hope that it will be covered by the LR warranty.
Post #83342 22nd Sep 2011 9:23pm
CG-SC
Not going too far off topic but I've had to top mine up a couple of times recently, nothing drastic (the low coolant light hasn't come on) I noticed that when cold, it had dropped from the upper level to midway between upper and lower.
I may be paranoid, but it's defo lost a little bit Question Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather.....
Post #83359 22nd Sep 2011 10:12pm
If it's being topped up by exactly the same amount it could just be finding its level
Post #83360 22nd Sep 2011 10:13pm
