![]() | Home > General > NEWBE |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35755 ![]() ![]() |
seatbelt on before start or after? ... - .- -.
Probably a tracker fitted so its something you will need to learn to live with.... |
dannyp15 Member Since: 21 Sep 2011 Location: essex Posts: 244 ![]() ![]() ![]() |
Thanks for that I will check it out. I don't wear a seatbelt so I will put it on then try again |
Mikeyjd Member Since: 14 Jun 2011 Location: Wrexham Posts: 543 ![]() ![]() ![]() |
Just a question. Why choose not to wear a seat belt? Apart from the fact it is illegal, all research points to it being the safer option in the event of a crash. I speak as somebody who regularly attends road crashes and has to cut people out of cars etc. No longer FF owner but still interested. Present car Jaguar XE ............................................ Previous car Td6 SE ................................ Previous LR- Disco 300TDi Auto |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6816 ![]() ![]() ![]() |
Seatbelt was my first thought, but assumed no-one would be daft enough not to belt up these days! |
+1 |
I no its dumb and I should no better. My gf is a paramedic |
Wise move ![]() Had- 2008 TDV8 Vogue SE in Java black Had - 2007 S/C in Stornoway Grey |
hi all
if the radio goes quite it suggests that its something to do with that..i would concentrate on the touch screen and see if the nav/rse is bleeping.. ... - .- -.
thanks scarey
might not be that but its a process of elimination.. ... - .- -.
cheers mate |
rayc Member Since: 13 Sep 2011 Location: deal, kent Posts: 105 ![]() ![]() ![]() |
Bluetooth? 08 model TDV8 Vogue SE Rimini Red/ parchment. 04 TD6 Vogue Oslo Blue / parchment
