Home > Maintenance & Mods (L322) > coolant leak from back of engine (solved)
pretlove
ive tried searching wiki to get a diagram of the coolant pipes at the back of the engine but with no joy..
basically when i went to get back in my car after going in the garrage i noticed a large puddle of water under my car coming from where the gearbox is bolted to the engine
im pretty sure its not my aircon as (sorry dan) i never use it and its always switched off plus ive been loosing a far bit of coolant.......ive striped the top engine cover off and had a look down the back but its difficult to see so any help would be appreciated Thumbs Up "RANGEISM WILL NOT BE TOLERATED"
Post #83627 24th Sep 2011 2:57pm
pretlove
also theres a link to this part and i think that may be the part im after sorting
http://www.autopartswarehouse.com/sku/Land...ID=k244266
this was the problem as it was the part i suspected so i removed it and vola there was a hole in it ive got pics so will add them later to show exactly where it is for future "RANGEISM WILL NOT BE TOLERATED"
Post #83628 24th Sep 2011 3:25pm
This should give you a diagram of the cooling system
http://www.datafilehost.com/download-8ac9ba28.html
Post #83630 24th Sep 2011 3:34pm
pretlove
thanks nice day but ive sorted it now ...ive managed to cut the hose back enough to loose the hole and now just gonna order a new one from brit part Thumbs Up "RANGEISM WILL NOT BE TOLERATED"
Post #83631 24th Sep 2011 3:56pm
pretlove
i just need to see if i can find the uk part number so i can order one as ive checked britpart and had no joy also the part isnt shown in the files that niceday posted Confused "RANGEISM WILL NOT BE TOLERATED"
Post #83632 24th Sep 2011 4:04pm
JustinP
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
Microcat online should help you to identify the part number.
http://lrparts.ru/engl/
Gone - Range Rover Supercharged 2006
Post #83637 24th Sep 2011 5:23pm
Pret
That section of hose if I'm right comes from the rear coolant manifold and then head off towards the heater matrix. It's a tawt of a piece! I couldnt get mine off so ended up disconnecting it from the clip end. Where it joins the manifold was the largest leak I had. If you want me to track the part number let me know.
Pics of mine here: http://www.fullfatrr.com/forum/topic6714.h...valley+pan
pic numbers 6,10,12
part number: JHC000081
Brit part: http://www.brit-car.co.uk/product.php?xProd=123204 [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #83655 24th Sep 2011 8:54pm
pretlove
cheers rob thats the part mate Thumbs Up
well ive now drove the car for 2 days on fairly long journeys and havent lost a drop of water Thumbs Up "RANGEISM WILL NOT BE TOLERATED"
Post #83794 25th Sep 2011 8:49pm
pretlove
Post #83796 25th Sep 2011 8:58pm
Good stuff. I couldn't get mine off the manifold until it was removed from the car. A good test for a leak is drive the car as normal. Lock it up as normal and in the morning open the bonnet and take the lid of the expansion tank. If you get a hiss your doing good as its holding pressure. If you don't it's loosing the pressure somewhere. Be it a leaking hose to the deaded HGF. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #83802 25th Sep 2011 9:40pm
